Coma or collimation issue? (SkyWatcher 150PDS)
5 replies331 views
Andrzej Skrobski avatar
Hello
I'm relatively new to the hobby, started last year with a basic reflector on a Go-To mount.
I'd like to get some advice regarding poor quality of my shots.
My equipment:
SkyWatcher Explorer 150PDS
SkyWatcher EQM-35 Pro mount
Nikon D7200
ZWO EAF focuser
APT for automation and acquisition
1.It is very difficult to get a proper focus even when using the auto-focus feature in APT software. It is so bad plate solving fails most of the time.
2.I see distortions in the corners of every shot, the further from the center the worse they get.
Is this coma, collimation issue or something else?
Some samples below to better explain these issues. 100% crops from corners and center.
Full size photo: https://www.astrobin.com/rkmc2s/
Bottom left corner:
Bottom right corner:
Center:
Top left corner:
Top right corner:
Best regards
Andrzej
R8RO avatar
Looks to me like it might be Coma + Astigmatism. I see you don't mention any Coma Corrector in your gear, without that the coma will be hard to get rid off. The astigmatism however can be fixed by not overtightening collimation screws and loosen the tension on your primary mirror cell.
Guillermo de Miranda avatar
Loosen your mirror clamps. They are tightened down for transport but it warps the mirror ever so slightly. This can cause all sorts of weird optical aberrations. The rubber clamps should not touch the glass.
Mike Dobres avatar
As stated above - you need to use a coma corrector: Skywatcher makes one: http://skywatcher.com/product/f5-coma-corrector-2/
I have the same:It works great on both my SW 130PDS and my 350/14 inch SW Dobson.
If you still see problems, then loosen clamps and play with collimation.
Mike
Lorenzo Dal Molin avatar
Hello,
The coma corrector is mandatory. If you don't use it you will always have deformation. But if that were the only problem you would see a perfectly radial deformation and a perfect photo center. For that, in my opinion you have to check the collimation. The considerations on the tightening of the mirror are correct. You may have slight astigmatism due to this. Something like the coma effect could also result due a wrong distance of the camera sensor from the plane of the corrector lens. I know that all this is complicated and that's also why the problem of deformation is omnipresent in my photos!smile
Andy Wray avatar
I would get the Skywatcher coma corrector and move to Nina
Newt Astigmatism: tilt or secondary mirror?
Hello, I'm struggling to get good star shapes across images from my ONTC 10" F4, specifically around the corners. I tried everything and can't seem to locate/confirm the source of my problems. Some information about the setup: General Se...
Newt astigmatism causes corner distortions; directly addresses author's corner distortion issue.
May 24, 2024
Request help with collimation
Hi all, I recently purchased a 190MN and have so far been disappointed with its performance, although that could be be because I don't know how to collimate it properly. An example uncalibrated image is shown below. Much of the image shows distor...
Collimation problems cause focus and image quality issues like author describes.
Oct 6, 2024
Why are my stars shaped like flat discs???
If I hadn’t seen it, I wouldn’t believe it was possible. A little backstory: For various reasons, I’ve struggled with collimation on my Meade SN8. Finally feeling I got it down, I went out 3 nights ago and got the best collimation I’ve ever had. This...
Poor collimation causes star shape problems; relevant to author's distortion complaints.
Jul 27, 2024
