Samyang 135+ filter wheel or drawer + asi6200
7 replies603 views
Vladimir González avatar
I have a big problem to achieve correct focus. Somebody solve with this setup?
samyang 135 ( for nikon ) + adapter ( zwo ) + filter wheel or drawer ( zwo , usually 20 mm ) + zwo camera asi6200
F mount lenses require 46.5mm of backfocus. The ASI6200 needs 17.5mm by itself which leaves 29mm to play with. The following adapter/filter drawer from ZWO would do the trick:
https://www.365astronomy.com/zwo-2-filter-drawer-for-nikon-lenses-with-male-m42-connection-for-the-camera?path=160_303
You'd still have 0.5/0.7 mm of extra backfocus to play with, depending on the filter you'd be using. You'd be needing a M54 to M42 female-male adaptor to go with it. There will be still some vignetting I'm afraid. Custom modification of a standarf filter drawer with a M54 back thread is another possibility but isn't in the ZWO catalog. Otherwise you'd need a ASI filter wheel for 2" filters and the following adapter:
https://astronomy-imaging-camera.com/product/nikon-lens-adapter-for-2filter-wheel
Carastro avatar
Many have problems like this.  I wonder whether this might be your answer, you need to remove the bayonet and screw this to the back of your lens.
https://www.firstlightoptics.com/adapters/astro-essentials-samyang-lens-to-m48-adapter.html
Carole
Hi, thanks. It’s a good possibility.
Carastro avatar
I should add that you will not find that adapter anywhere else as it was designed by a member of Stargazers Lounge having the same problem as you and made by First Light Optics the sponsors of Stargazers Lounge.
Carole
Achim Schaller avatar
I had a similar problem but Sony e-mount and an ASI 294mm pro and I built my own adaptor:
https://www.cloudynights.com/topic/810468-diy-asi-to-sony-e-mount-adapter-with-filter/
Clear skies,   Achim
Carastro:
Carole
That won't work. It is for a Canon fit not a Nikon. You'd need to add a 2.5mm spacer to make it work.
Well Written Concise
Carastro avatar
I believe the bayonet gets removed altogether, it certainly fits some of the more modern CMOS cameras, but not sure which since I just know it doesn’t fit my Atik cameras.
The Retailer knows what cameras it will fit.
Carole
Samyang 135 backfocus calculating problems with zwo 2600+efw
Hi i have this lovely lens from 1 year ago. Till now i used whit my last 294mcpro but now i have zwo 2600mcpro+2600mmpro attached to efw filter wheel. The backfocus for this lens is 44mm (canon mount) so i removed the 2600 tilter+efw+m48 adapter (10m...
Backfocus calculation issues with similar ZWO camera and filter wheel setup.
Nov 18, 2024
ZWO EOS adapter light leak
So I have discovered that I have a light leak in my imaging train using my Rokinon 135 lens. I am using a ZWO 6200 attached to the 5 position filter wheel ( tilt plate removed) the ZWO EOS adapter, and that is connected to the Rokinon 135. Through tr...
Light leak problems with ZWO camera, filter wheel, and 135mm lens setup.
Jul 28, 2024
