Is Anyone Using the WO Flat 61 R
6 replies404 views
John Noble avatar
Tried to use my new Flat 61 R last night and couldn’t get to focus. I’m very familiar with the WO adjustable flatterers but just couldn’t get to focus.
Im using a ZWO ASI 2600 with filter wheel and OAG and have the adjustable flattened set to 1 mm as suggested. That gives the 56 mm back focus.
To reach focus I’d need to go negative on the focus tube - ie fully retracted still too far away!!!
I ended up switching back to my 61A which works fine at 31 mm of extension.
Im hoping I’ve just missed something!
I did switch out the rotator from the 61R with that from the 61A to get closer but still no deal.
Thanks
John Noble avatar
Ok I fixed it for future reference the focused extension with the Flat 61 R is around 9 mm and the 61 A is 30 mm.
My filter wheel was clashing with the dove tail bar preventing me reaching the 9 mm - something that wasn’t obvious in the dark at 20 f.
Another classic it’s dark and I’m cold error!
Michael J. Mangieri avatar
I'd be curious what you think of the Flat 61R.  I'm having some serious coma and star distortion with my ZS61 and ASI2600.  Contacted WO about a possible defect in the flattener.  They gave me some things to try and so I'm waiting for clear skies to try again.
John Noble avatar
Michael
I was able to get the set up working tonight I used the 1 mm off set recommended by WO and the field looked OK. I have a bit of tilt in one corner but I think the flattener is working just fine.
Good luck with yours
John,
After re-measuring everything and adding the ZWO Tilter to the mix I was finally able to get the Flat61R working.
Carles Dalmau avatar
Hi!
Is still everyone happy with the reducer?
Would someone want to sell his?
Carles.
Rob Kiefer avatar
Carles Dalmau:
Hi!
Carles.
I have the reducer. I struggled quite a bit finding a good backfocus. Then there was some tilt. After adding the Neumann Tilter, I was getting acceptable results. (I prefer spacers instead of adjustable reducer / flattener). Then I had some pinched optics as well and I had to loosen the set screws a bit. After sorting out all the little problems, the scope performs very well. Selling the reducer - nope, now the system is running quite well and I plan using it for some widefield images again.
Rob
Zenithstar 61 with Orion Field Flattener
Hi folks: Quick question here: I'm thinking of upgrading from my ST80 to the Zenithstar 61 for my Skyguider mount. My local telescope shop has recommended the Orion Field Flattener to go along with it, as they don't carry WO products (the Z61...
Direct experience with WO flattener for Z61 alternative comparison.
Dec 12, 2020
Can't achieve focus on Lunt 50 with 2x Powermate
Hi, folks. I have a Lunt 50 with 600 BF and Saturn-M SQR camera. It works a treat. I've tried attaching my Televue 2x Powermate (2" version) but cannot achieve focus. It seems I need to be closer in than I can manage. I have read that the 50...
Focus adjustment issues with optical accessories similar to flattener problem.
Oct 10, 2024
Replacement Focuser for Esprit 100
Hello Everyone, I have had my Esprit 100 now for about a year and have had very good luck with it. Well that is until I moved from a filter drawer to a 5 x 2 filter wheel 😞 Once I got everything tweaked in I had about 1 nights worth of data collectio...
Focuser and back focus distance issues relevant to focus problems.
May 23, 2024
Achieving a flat field when using the x0.7 Reducer
I have a brand new Celestron EdgeHD 0.25 with the x0.7 Reducer and the first time I used it with my ASI6200MM Pro full frame camera I could not achieve a flat field, even though I had the Celestron T-adapter and exactly 55mm back focus. I tried adjus...
Flat field and reducer adjustment similar to flattener focus challenges.
Sep 14, 2024
