Tweaks for the Star Adventurer GTi
11 replies1.2k views
Michael Ring avatar
It would be nice to know how others have tweaked this nice little mount to make it even better.
From my side, the one tweak I did and that I can highly recommend is to replace that very short Vixen Clamp with something a lot better.
My issue with this clamp is that it is simply to short to properly grab the Vixen Style foot that comes with the Ascar acl200.
So what I did was to order a clamp that is suitable for both Vixen and Arca Suisse dovetails from Teleskop Express in Germany.
Then I 3D printed a small adapter to fit the screw holes of the custom clamp to the  holes of the Skywatcher GTi.
Here's a closeup of the adapter plate and the clamp:
and here the fully mounted scope:
and here's the STL in case anyone is interested:
Skywatcher GTi Adapter v2.stl
Michael Ring avatar
Forgot another tweak I did, a short extension for the counterweight bar which allows me to put the Askar in balance, it consists of a simple M12x60 Screw surrounded by a 3d printed part that has the same diameter as the original bar.
MrPhoton avatar
Hi
To 3D-print the counter weight extension is a good idea! Thank you for this!
For the dovetail, I need to check my needs with my equipment.
Thank you for sharing!
Clear skies, Jens
Philip F. avatar
Where did you get the mount for the EAF?  I like it mounted off to the side like that.
Michael Ring avatar
I designed & 3d printed it myself, only thing to buy is the GT2 belt, here's the STL:
ACL200 ZWO Autofocus v1.stl
Piermi avatar
Hi Michael,
I'm looking for a similar setup. Can you share the clamp bought from Teleskop Express?
Kind Regards,
Piermi
Michael Ring avatar
Piermi avatar
BenVonPrank avatar
I had the same issue ! And also designed a 3D printed adapter - but for another clamp style
The clamp I had is the same as this one : https://www.aliexpress.com/item/4001098158402.html
and here is the adapter STL : https://www.printables.com/model/388265-star-adventurergti-replacement-vixen-adapter
It carries my Zenithstar 61II + reducer + guide scope + Asiair without issues.
Stefano Zamblera avatar
Michael Ring:
*** Thank U very very much!!! ***
Imran Sultan avatar
Michael Ring:
Hi, do you mind sharing the STL for the counterweight extension bar? I was thinking of designing something exactly like this!
Pavel Vorobiev avatar
Michael Ring:
Good idea. Could you share the STL for this, please? Thanx in advance
Guiding Tips for the Star Adventurer GTi
The Star Adventurer is a very nice little mount that in my experience needs some tweaking in order to get good guiding. I have spent quite a while trying to get the best possible results from that little mount, but at least for me this is still a fig...
Feb 9, 2023
Both posts discuss modifications and improvements to small astronomical mounts to enhance their performance.
