Ioptron Sky Guider Pro DEC Oscillating Error
iOptron Skyguider Pro 2 replies65 views
Tomas Chylek avatar
Does anybody experience the same?
When guiding RA with PHD2 (DEC has no motor), I am experiencing periodic oscillation showing in DEC (I am not talking about RA) with p-v over 12 arcsec, sometimes even more (see the first picture, DEC curve is yellow). Polar alignment is close to perfect as shown in second picture when the RA guiding is turned off and guiding advisor is running.
Is such large Declination oscillation normal or is my Sky Guider faulty? I am talking about declination only. I appreciate your insight!
Mark Germani avatar
Hi Tomas:
I've not used the guiding advisor, so I'm not sure I follow what's happening in the second image, but your first image looks VERY similar to how my Skyguider guiding graph normally looked, with the long wandering DEC patterns. Sometimes mine would wander right off the graph and I would check my guiding and see RA only for most of the evening. Sometimes the DEC would hold still for several 6-minute subs only to slowly wander away again. My PAs were pretty tight.
In the end, my stars were still mostly round when reviewing the subs - I was able to keep about 80% of my 6-minute subs. I upgraded to the William Optics base (best upgrade I ever bought) and I was sometimes able to keep 100% of my 6 minute subs, and I even stretched that to 10 minutes. If I'm being honest, I can't remember if the WO base improved the DEC oscillation, but it did happen nearly every night, to some degree.
The most important question is: how do your stars look? If your RA and DEC error balance each other during your typical exposure length (other factors like sample rate can come into play too) then this might be tolerable, or even unnoticeable.
I'm really curious to see if anyone else can chime in with the reason this is happening. Is the rig sinking into the ground slightly? Is the latitude slipping? Would really love to know.
Mark
Tomas Chylek avatar
Hi Mark,
thanks for your reply and confirming that you are experiencing the same. Yes, the stars are reasonably round but I have not used focal length over 200mm or exposures longer than 2 minutes.
What is puzzling and I cannot explain is that without guiding commands (second picture) the DEC is perfect, but once I turn the guiding on (first picture), DEC starts wandering.
If it was a simple cross-talk between RA and DEC mechanical axes, you would see it in both cases.
Tomas
17 things I did during the last year to greatly improve my astrophotography
17 things that I did in the last year that improved my astrophotography. Hi, I am an amateur astrophotographer. I have spent about 10 years doddling with it, even taking a 3-year break during the pandemic due to work commitments. I came back to it in...
Not relevant to guiding oscillation issues.
May 22, 2024
Smoothness of RA motion on a one second timescale in mounts . What is normal?
I suspect that I might have a continuing problem with an RA oscillation in the movement of my Ioptron CEM70? It can be an explanation for Eccentric star shapes elongated along the RA axis direction. Interested to know if others have experienced or de...
Relevant; discusses RA oscillation problems in mounts similar to author's concern.
Jun 4, 2024
Another question about guiding...
I just want to put this guiding question out there and see what everyone thinks. Back in the day when guiding was done manually (oh boy) it was normal to have a large and very precise worm and wheel on the RA and not much on DEC, maybe a tangent arm ...
Relevant; general guiding question discussion may address oscillation issues.
Aug 20, 2024
Newbie needs help with accurate reliable tracking.
I am new to astrophotography and to the forum. Have been using a Seestar for the last year while getting my HEQ5 mount, Evostar 120, asiair plus, asi533mc pro, Uniguide 50 guide scope, ZWO 5x 2 inch filter wheel. I lose tracking and don’t get good 30...
Relevant; newbie tracking problems may relate to declination oscillation causes.
Sep 29, 2024
Sky-Watcher Star Adventurer GTi: Declination Spinning after a Couple of Hours
Hi, everyone. I have my SW Star Adventurer GTi since March and have been working with it since then. Both with ASIAir Plus and INDIGO A1. Suddenly, for the last couple of weeks I'm experiencing a strange issue: after guiding for about 2 hours or ...
Relevant; discusses mount behavior issues including declination problems.
Oct 12, 2024
