Best gain offset for using 12 nm. Narrowband filters
ZWO ASI1600MM/QHY163M 6 replies234 views
Shawn Killian avatar
Hi everyone, I use optolong 12 nm. Narrowband filters for my qhy163m, I was wondering should I use a lower gain and offset for these filters due to their, wider bandpass as supposed to say 5 or 6 nm. Filters ,also what is a good recommend gain and offset for these filters, using them on an f6 60 mm Astro tech Ed doublet. Any help would be appreciated. Thanks! Shawn.
Jon Rista avatar
I would only use a lower gain if you feel you clip the stars too much. Usually you can handle some amount of star clipping and once you stretch the data, unless you use more exotic means of stretching (i.e. a masked stretch or exponential stretch), you won't be able to tell the difference between the stars if they were clipped, vs. just highly saturated.
I recommend using Unity Gain for NB at f-ratios of f/4-f/6. I would use "half unity" (Gan 76 on ASI) for scopes faster than f/4, and "double unity (about Gain 200 for ASI) for scopes slower than f/6, just as general starting points. You should adjust as necessary based on how you feel about star clipping.
Thanks John, I will try your advice, as soon as I'm able to see the stars again!
Hi John, by the way  do you know what unity gain is on the qhy 163? I can't seem to find out what it is there is only a dso preset, but it seems to high to be unity gain.
Hunter Harling avatar
By the way- I did a test by capturing an image with gain 10 and one with gain 163 with my ASI1600 and found very little difference in the image…
I have noticed the same thing, there doesn't seem to be much difference in gain settings on my qhy neither, I just mainly use the preset gain/ offset.
Jon Rista avatar
QHY has had different gain settings at different times. I think originally it was 1-50, then 1-500, now I think it is 1-50 again. The ZWO cameras are 1-600. Gain 139 is unity on the ZWO, so I would assume a gain around 11-12 is probably where you will find unity on the QHY.
Mono capture process
Hi all, about to get my first mono camera and was wondering if anyone can give me any advice/experience on a process when capturing multiple filters? (I'm using an ASIAir Pro/EFW here, so everything is automated. Not concerned about effort, more ...
Discusses mono camera filter capture process relevant to narrowband imaging.
Jun 1, 2021
How do you deal with camera Offset?
Hello folks, until now, I did not really care about the offset settings of my ASI183MM camera. I just took the images setting exposure time and gain. Then, an almost unmentionable comment from amother user made me think of using the offset parameter ...
Directly addresses camera offset settings similar to author's gain/offset question.
Aug 8, 2021
Galaxies & CLS Filter
Hi there: I'm wondering if I need to rethink my galaxy imaging techniques. Briefly, here's my setup: - WO Zenithstar 61 apo - Skyguider Pro star-tracker, unguided - Canon T3i/600D unmodified I'm imaging in my backyard, aiming away from st...
Discusses filter selection and imaging techniques for specific equipment setup.
Mar 12, 2021
