qhy 163m monochrome cmos camera 12 nm. Gain and offset
3 replies•258 views
Shawn Killian avatar
Hi, everyone, I was wondering if I am using 12 nm. Narrowband filters for my qhy 163 m camera, should I use a lower gain and offset, because these filters have a wider bandpass, or can I use the same gain, offset as say 6 nm. Filters, and does anyone have a good recommend gain and offset for my 12 nm. Filters for the qhy 163? Any help would be appreciated. Thanks, Shawn
Roman Pierce avatar
Hello Shawn, I am going through the same sort of learning curve as well and because of this I am including a link that I find helpful, hopefully it will help you also? https://www.cloudynights.com/topic/671241-another-what-gainoffsetexposure-should-i-use-for-asi1600/
As a reminder, the ASI1600 uses the same sensor as the QHY163 so the information you will find with that CN post should apply.
Helpful Concise Supportive
Roman Pierce avatar
Thank you Roman, I will read the article you referred to, it has been a constant battle figuring out gain and offset. Clear skies! Shawn.
Mono capture process
Hi all, about to get my first mono camera and was wondering if anyone can give me any advice/experience on a process when capturing multiple filters? (I'm using an ASIAir Pro/EFW here, so everything is automated. Not concerned about effort, more ...
Mono camera filter capture process directly relevant to narrowband filter workflow.
Jun 1, 2021
How do you deal with camera Offset?
Hello folks, until now, I did not really care about the offset settings of my ASI183MM camera. I just took the images setting exposure time and gain. Then, an almost unmentionable comment from amother user made me think of using the offset parameter ...
Offset settings discussion applicable to QHY 163M camera configuration.
Aug 8, 2021
