AstroCapture325 avatar
I didn't realize that cutting and pasting from Word would cause formatting problems...
I am hoping that you can help me with autoguiding issues that I have been experiencing. Normally, my autoguiding is consistently good, with values about 0.6" to 0.9". However, my last two sessions I have been getting large errors in the declination axis. The errors in the declination axis appear to slowly oscillate between 30" and 40" peak-to-peak, if not larger. I have no idea if my issue is related to ASIAIR software or mount hardware issues.
My setup is as follows:
Skywatcher HEQ5 Pro mount (does not have Rowan belt mod)
WO SpaceCat51 telescope
ASIAIR Pro
ASI120MM mini guide camera
120mm guidescope
ASI183MC Pro main camera
Jackery Explorer 300 power station
I have tried rebooting the ASIAIR, checking cable connections, and varying the aggression and duration without much effect. I will note that I made very minor adjustments to the set screws in the declination axis to eliminate backlash prior to my problems occurring, but I checked afterwards and exercised the mount head a full 360 degress and did not detect any strange noises or signs of binding. I am not sure if that is a coincidence, or in some way related to my autoguiding errors, which started afterwards. I have also noted the mount making a "chirp" or clicking sound every now and then.
Not sure if it is helpful, but I attached the guide log from my last session PHD2_GuideLog_2022-10-15_203800.txt
Hoping someone has experience with this issue because I am stuck until I resolve this.
Thanks,
Jim
Michael Ring avatar
The clicking is exactly the effect I had when I did try to remove the backlash and created a little binding.
So your best bet will be to undo your changes to DEC.
When checking for binding later you will also have to do a full 360 degrees rotation of the Dec axis as you already did.
A good indication that you have overdone the adjustment is to manually rotate the gears of the axis that you try to adjust, it is easy to feel with your fingers when you have overdone the job. Ideally you go to the position where sound changes or you hear binding, turn off the mount (important!!!) and adjust by checking when the gears start to move without the need to apply much force.
When you cannot hear binding then slew to the same Dec pos where you saw Bad guiding and compare if there is a difference when you move RA or DeC gears.
Michael
Patrick avatar
I second Michael Ring’s response, based on my own experiences with my EQ6R and it taking two attempts to get the adjustment right. After my first try the quiding was much worse than before, as you are experiencing. The second attempt was far better , after backing off the worm gear, as I had introduced mild binding. I’m now at around .4 arc seconds with reasonable seeing.  It doesn’t take a lot of binding to have dramatic effects on tracking. There is an extremely fine line between having good gear engagement and binding. I found that listening to the pitch of the sound when doing a fast slew was effective. I would suggest doing the slew with the normal setup of equipment and correctly balanced. I assume you have watched some of the YouTube videos on this.
Helpful Insightful Respectful Supportive
Michael and Patrick,
Thanks for the suggestions! I will work on re-adjusting the declination axis this afternoon and hopefully try out tonight. I will keep the group posted on my results.
Jim
It worked!
Before I did any adjustments I tried rotating the declination gears manually. I had introduced so much binding that I could not even rotate the DEC gear. After I backed off the worm gear I did a manual rotation and everything was smooth and easy to rotate. I took it for a test run last night against the Veil nebula and was very pleased. My tracking errors were between 0.6 - 0.9 arc seconds, which is the historical performance of my mount.
Thanks again for the help Michael and Patrick!
Jim
Well Written Helpful Respectful Concise Engaging Supportive
Poor guiding and declination axis slipping on belt modded EQ5 Pro.
I've recently been given a Skywatcher EQ5 Pro mount that the previous owner has belt modded and I was trying this out on my second setup last night but my guiding was terrible. The mount just couldn't correct on the dec axis. here's what ...
Declination axis issues match your autoguiding problem symptoms exactly.
Aug 17, 2024
Calling all AZ-GTi + ASIair users... What guide settings do you use?
Anyone here using the SkyWatchwer AZ-GTi mount (in EQ mode) along with an ASIair pro? I've been running mine for a few months, usually carrying anything from a Canon 70-200mm f2.8 lens to a RedCat 51. It's been a great lightweight mount and I...
Autoguiding Issues — addresses autoguiding problems relevant to user's guiding performance
Jan 24, 2021
Sky-Watcher Star Adventurer GTi: Declination Spinning after a Couple of Hours
Hi, everyone. I have my SW Star Adventurer GTi since March and have been working with it since then. Both with ASIAir Plus and INDIGO A1. Suddenly, for the last couple of weeks I'm experiencing a strange issue: after guiding for about 2 hours or ...
Declination spinning problem similar to your oscillating declination errors.
Oct 12, 2024
Star Adventurer not holding polar alignment
Hi all! After one year of flawless use, I'm starting to have trouble with my Star Adventurer. On two of my last four imaging sessions, it's not holding polar alignment. I don't know what could be causing this, I follow the same workflow e...
Mount alignment issues could cause the guiding errors you describe.
Jul 10, 2024
Does the moon effect your guiding & PHD2?
It might just be a coincidence or due to another factor (seeing?), but I'm noticing that my guiding gets better as the moon gets low in the horizon. If I image somewhat near the moon my guiding isn't as good as if imaging in the opposite port...
Autoguiding issues discussion likely covers PHD2 settings and troubleshooting techniques.
Jan 25, 2021
