Pegasus NYX-101 Harmonic Gear Mount & ZWO ASIAIR Plus
2 replies526 views
Jerry Gerber avatar
Does anyone have any experience with this mount and the ASAIR Plus?
I am wondering if they'll communicate as well as the AM5 and the ASAIR Plus  together.
Jerry
Marcelof avatar
Well, as far as I know Pegasus hasn't delivered any of their new mounts yet (should be doing by these days), so it's hard to see any test of that at the moment.
Also it is not known if ZWO is going to allow AsiAir to work with a direct competitor (it certainly doesn't allow to use other brands' astro cameras).
kuechlew avatar
According to Pegasus the mount will use the LX200 protocol which is supported by ZWO. My understanding based on some of their reports at CloudyNights is, that they are testing this combination. Of course, as long as there are no customer supports it remains an open question how reliably the connection is going to work.
Clear skies
Wolfgang
HAE69B
Hello! I've been discussing this mount with a few owners and I am hearing mixed opinions. I am considering setting up either a 130mm refractor or a 185mm refractor at a remote imaging hosting site. If I go with the smaller refractor I'll put ...
HAE69B mount discussion; considers 130mm refractor setup similar to inquiry.
Apr 4, 2024
Has anyone figured out how to do a "Park" with the ASI AM5.
I know that NINA sends a park command to the driver and the driver actually does the parking. The AM5 does not have a park command in their driver. Has anyone figured out a work around like maybe some script that puts the mount at a predetermined pos...
ASI AM5 driver and command functionality directly relevant to mount compatibility.
Sep 13, 2024
Recommend Antlia Quad Band Anti-Light Pollution Filter for a Bortle 8/9 Backyard?
Hey all, I am about to acquire a ZWO AM5, Redcat 71 WIFD and ASIair Plus to try some imaging in my (sadly) Bortle 8/9 backyard. I know the best solution is traveling to darker skies but due to family situation it is difficult to do that and being in ...
Acquiring ZWO AM5 and ASIair Plus; discusses exact equipment pairing mentioned.
Apr 11, 2024
AM5N?
Apparently, ZWO have rolled out a 2nd gen AM5, the AM5N. Any idea what this entails, as I couldn’t find any info online? https://www.teleskop-express.de/en/asi-zwo-129/mounts-equatorial-with-goto-20/zwo-am5-harmonic-equatorial-mount-goto-travel-mount...
AM5N second generation mount; relevant to AM5 mount discussion and updates.
Jun 18, 2024
ZWO AM5 and N.I.N.A meridian Flip
Hi everyone does anyone have any experience using the zwo AM5 mount and the meridian flip on NINA thank you clear skies
ZWO AM5 and software integration; addresses mount communication and control issues.
Jul 9, 2024
