Thanks for the comments. Here are some pictures and technical descriptions of the parts, with comments from some gamers:
https://pcpartpicker.com/builds/edit/?userbuild=CQDcCJThey also comment that my graphics card is low end, but I do not believe that comes into play in PI. StarXterminator is faster by a lot with this system.
Also, note that I have 64GB of RAM that is now being used for 8 4 GB RAMDisks and that doubled the swap speed in PI. Was noted that the swap speed only helps on certain operations that are reversible, not WBPP for example. See the PI thread.
Yes, the Samsung blasts away. I have a second oen on which Linux is installed (Kubuntu- the PI development platform). You can change boot OS relatively easy in the ASUS BIOS.
Linux is faster out of the box- hardware to hardware- than Windows 11, however Windows 11 catches up with the RAM Disks. I am sticking with Windows 11 to keep all in synch with OneDrive... not sure there is a way to use OneDrive on Linux. Also I have installed my Office 365 apps on the install and keep in crisp communication with that directly from this install.
I have retired two old Windows 10 machines now and all my legacy files and in the Mirror drives... fingers crossed as this is not RAID, but RAID is a pain... not sure I mentioned here but Windows 11 does NOT support RAID, at least 1 or 0. I am going to try to keep my registered files there for potential reuse, but it is very space hungry since my ASI6200 has 50MB images.... maybe I will back up on AWS when the time comes.
