iOptron CME26
IOptron CEM 3 replies86 views
CieloBlue avatar
Does anyone know if it’s possible to power the Asiair plus with the DC12v iOptron output ?
See attached pic.
Many thanks
Bob Stevenson avatar
Hi CieloBlue,
From a quick review of the iOptron manual, it looks like this 12V output is meant to power the LED for the polar scope. My older CEM60 has a similar connection, although the voltage is not labelled. Given that there is no current output rating on this 12V connection and the barrel jack may be the wrong size, I would avoid trying to power an ASI Air from this connection. The Air may need a lot more current than the CEM26 can provide which will cause problems for your mount electronics.
Bob
Well written Helpful Insightful Respectful Concise
Reza Mohammadi avatar
If you refer your mount instruction manual, it is mention the maximum allowable amp of the output 12v. for the cem70 it is totally 3A for output 12v together.
CieloBlue avatar
Many thanks for the info, that’s very hopeful .
Cielo
Asiair plus
Hi, Does anyone use this to capture data for planets or prefer use of laptop. I've read some issues concerning fps rate not being high enough. Looking forward to your experiences. Thanks Mark
Asiair plus — discusses Asiair plus usage and potential issues with device.
Apr 28, 2024
Solving Issues During Polar Alignment
Recently I have been having sporadic issues during Polar Alignment in the AA+. It will often see XXX number of stars but fail to solve and move on. If I cancel and retry sometimes it will carry on and sometimes not. Change exposure try again, sometim...
Solving Issues During Polar Alignment — addresses troubleshooting Asiair plus connection problems.
Aug 28, 2024
How to Connect to AM5 from ASIAIR+ ?
Hi everyone, I’m trying to connect to my AM5 mount from my ASIAIR+ via WiFi, but I keep getting a connection error. This is what I have done so far. 1. Powered up the AM5 and connected the hand controller. 2. Used the SkyAtlas app to update to the la...
How to Connect to AM5 from ASIAIR+ ? — covers Asiair plus connectivity and power configuration.
Sep 30, 2024
ZWO EAF and Guidescope Disconnects
I have the ASI2600 MC Pro and ASI183 MC Pro cameras on two different setups. Both are interfaced (power and connection) through ASIAIR+. I get intermittent disconnects of either my ZWO EAF and/or ZWOASI120mini camera when connected to either camera&#...
ZWO EAF and Guidescope Disconnects — discusses Asiair plus power and interface issues.
Jul 27, 2024
