TS ONTC 200/900 f4.5 Carbon tube
R8ROatlejqAndy WrayAlan BrunelleReg Pratt
29 replies1.3k views
R8RO avatar
Hello,
I am currently looking to upgrade my main imaging tube to one of TS' ONTC carbon tubes and I was looking at the 8" f4.5 one. Before I pull the trigger I wanted to put my ear to the ground and see what people say about it? If anyone on this forum have one or has experience with them, what do you think? Is it a good tube for the money, what would be comparable tubes to look at? How should I spec it out (focuser, base, dovetail etc). OOUK mirror optical quality?
Really anything that might help me make this decision is appreciated!
Clear skies!
Respectful Engaging
Andy Wray avatar
Interesting:  you are not changing things much … a 200PDS with its coma corrector is exactly the same focal length.  What are you hoping to gain?
R8RO avatar
Andy Wray:
Interesting:  you are not changing things much ... a 200PDS with its coma corrector is exactly the same focal length.  What are you hoping to gain?
Mainly better build quality but the superior optics are a nice plus. I would be going down a bit in focal length since I am using the TS GPU CC but not too concerned about that since I would be trading it for a bit extra light gathering power. The plan in the long run is to also add a 0.73x reducer/flattener to make it a super fast imaging Newtonian.
I don't think the supposed "superior optics" is going to matter a lot for AP, once you're diffraction limited you'd hit the buffer. Why do you think you are going down in focal length with the TS GPU? AFAIK isn't reducing the focal length at all and there is no extra light gathering power even if it did.
R8RO avatar
This was in response to Andy's question. He said I would be at exactly the same focal length, which is not true 900≠1000. Me going down in focal length would be from my 1000/200 F5 scope to a 900/200 F4.5 scope. This would also give me a bit more light gathering capability compared to my current scope.
As for superior optics, I am talking about the quartz coating, 97% reflectivity, bigger secondary and Strehl graph and certificate.
atlejq avatar
After using a 200 PDS for years I upgraded to this exact telescope.
I use mainly for deepsky imaging with an ASI294MM (23.1 mm diagonal). The telescope is very thermally and mechanically stable. It is carried well by my EQ6-R and would probably sit on a HEQ5 too. Judging from the output, the mirror must at least be of acceptable quality.
The only thing I wished I had included from the start is a screw-threaded focuser (it came with a cheap focuser and I changed it to a Moonlite CR2 which also lacks threading). Exactly what focuser you should go for will depend on your coma corrector of choice. I can elaborate on this if you want.
I personally went for CNC rings and 2x Losmandy dovetails. This may be an overkill, the scope is rather light. But it will enable you to load the setup with heavy accessories.
Have a look at my recent pics for some information to base your decision on. I recently started using a Paracorr 2 which seems to be a perfect fit, it lands me at about f/5.1 (the mirror is actually slightly faster than f/4.5). I personally would avoid the GPU due to its vignetting.
Alternatives may be an 8" in the TS UNC series or Skywatcher 190MN, but I have not owned any of these myself. From what I read they are all of good optical quality, but lower mechanical quality than the ONTC series. UNC scopes are also less versatile when it comes to changing the primary mirror position to adapt to different coma correctors/planetary imaging/visual. Another alternative may be the similar ONTC 10" f/4.
My last image: https://www.astrobin.com/k8l808/B/
Uncropped test data from yesterday (there is some vignetting in the corners from the 1.25" filters which are slightly too small).
Mounted in the basement:
Andy Wray avatar
I was being a bit simplistic, sorry!  The 200PDS with the stock coma corrector does end up being a 900mm F4.5; hence my comment.  I have that exact setup.
Well Written Concise
This was in response to Andy's question. He said I would be at exactly the same focal length, which is not true 900≠1000. Me going down in focal length would be from my 1000/200 F5 scope to a 900/800 F4.5 scope. This would also give me a bit more light gathering capability compared to my current scope.
Andy was saying it because with the SW CC there is a a focal reduction at play. It is still the same aperture no matter how you cut it and the difference in reflectivity is trivial (94% vs 97% I believe).
If there is SiO2 coatings (the blurb doesn't say) most if not all modern mirrors out there have it. The substrate is equivalent to Pyrex so no quartz there. I had bad experience with OOUK coatings, very bad ones too so buyers beware. A bigger secondary you can get one yourself if you're so inclined (but you lose a bit of light gathering area there). As for the certificate I wouldn't put my money on it being 100% accurate, besides making no difference in actual practice. And if you really need one I can provide you one free of charge.
R8RO avatar
Thanks a lot for your response! I would be working with pretty much the exact same setup (294MM) as I am also upgrading my mount from a HEQ5 to an EQ6R, sub the Paracorr for my TS GPU. In regards to the focuser; I am talking to TS custom service and they recommended this focuser. I initially was thinking of mounting a Baader Steel Track but have not yet decided.
R8RO avatar
There would be no way for me to know that since he didn't specify what CC he was using and I was simply going of my own experience with the TSGPU
I am well aware that the aperture won't change. As I mentioned in my first response, it would simply be a nice plus. My main reason for upgrade would still be for the far better build quality, customization options, carbon tube and mirror mountings. I have had major issues with my current Skywatcher scope to the point that I no longer want to spend twice the money it costs on trying to get it to work as I want. So I instead opt for an upgrade, hence the initial topic, which we have strayed from.
Andy Wray avatar
Just food for thought:  I'm also thinking about a long term upgrade for my 200PDS and am yearning after the Takahashi Epsilons.  I won't make the move though until I know I've made the most out of my 200PDS which I certainly haven't yet.
atlejq avatar
I have ordered a Steeltrack myself, together with a threaded adapter for the Paracorr 2 to see whether I can gain collimation stability. However I am yet to receive it so I can't judge its quality. Nor do I know anything about the focuser TS recommends to you
R8RO avatar
Andy Wray:
I did look at some of the epsilon series but I don't think that I want to step down in aperture and the price difference is just way out of my budget for the foreseeable future... No doubt that they are quality scopes, just not sure of the "bang for buck" factor
R8RO avatar
Not sure why they recommended just this one but I think it's because of the fact that I have the TSGPU and it apparently plays nicely with the threads on that corrector. We'll see, like I said: I have not yet decided. But if you do end up getting first light with the Steel Track before I buy mine, please report back!
atlejq avatar
BTW a word of warning - I have had considerable problems with pinched objects and malformed stars with this setup.
This has been a confusing thing to sort out, but it seems that 1) heating the primary slightly with a thermal band around the screws on the outside and 2) being careful not to overtighten anything in the primary mirror cell will alleviate the problem.
Helpful Concise Supportive
R8RO avatar
Appreciate the warning, I am familiar with pinched optics as my current Skywatcher mirror came pinched from the factory. I have heard that the main mirror cell is very easy to work with though, makes collimation a breeze.
Andy Wray avatar
Sorry if this is off-topic, but just out of interest, what issues are you having with your 200PDS?  It would be good to know if they are things I am struggling with as well.  My main issue is star quality and diffraction spikes that I think are caused by mirror clips.
R8RO avatar
Andy Wray:
The main issue I've had is probably reflections and issues caused by tilt in the focuser. When I first got the scope the mirror was pinched and my stars looked very bad. Then after addressing that and mirror clip diffractions (which you mentioned) by installing an aperture mask I noticed my spikes were not symmetrical and this was due to the spider veins being flimsy and not properly tightened. I bought an Artesky spider/tube ring to increase rigidity and improve collimation. My main beef other than the reflections (which I still have. Rendering the scope useless for anything other than narrowband in my bortle 8 zone) is with the quality of the focuser and the design of the primary mirror cell. Again which is why I put so much weight on build quality now that I've decided on upgrading.
Fair enough. Again, not sure whether the carbon tube really helps or not. In my experience I never had issues with the metal ones but then YMMV. Money wise invest in a good focuser. Some say they need to be threaded to accept threaded CCs. I disagree. But I'd go with the Baader Steeltrack over the others. Moonlites are good (I have 2 of 'em) but not the best bung for the buck. The main issue will be the stability of the primary cell and that of the secondary spider. I suspect that the primary cell is going to be miles better than the ones they serve the UNC/Photons with (and OOUK ones too).
atlejq avatar
I can confirm that the ONTC spider is much stiffer and more durable than the 200 PDS spider.
Reg Pratt avatar
10" ONTC here. I went with the 2" Feather Touch focuser paired with a Sesto Senso 2 motor. To date I have not had to use any backlash compensation for autofocus. Also am not experiencing any tilt or flexure issues with the compression ring and TSGPU coma corrector. Coming from Moonlite focusers I was concerned about not being threaded to the drawtube but it hasn't been an issue at all. The primary mirror clips were a bit loose but took very little effort to tighten. Its been a workhorse for the 4 months I've had it. Holds collimation no problem when I leave it mounted.
I previously had 2 steel tube GSO F4 Newts and while they worked for the most part there was a lot of mechanical issues ( to be expected form cheap scopes). There's none of that nonsense going on with the ONTC. Thing is built like a tank and even at 10" its very light. I'm of the opinion that the carbon tune does make a difference. Not only does it make the scope a good deal lighter but it also cools very fast. I usually have my scope uncovered within an hour or 2 of night and there are many nights where autofocus may only run once or twice. I've had nights where it didn't run again after the initial run (NINA triggers AF after a 10% HFD increase).
When I was looking to get into newts I didn't feel there was a whole lot to choose from for a higher quality scope. I considered OOUK but read some less inspiring things about them. In this price range I don't think you will find a better scope than the ONTC. The last handful of images on my profile were made with it if you're interested.
Side note: Mine has GSO mirrors as is the default for UNC and ONTC scopes. TS does sometimes take OOUK parts and put them into their own carbon tube though. I know someone who had a 12" with OOUK optics and as far as the mirrors themselves were concerned the quality was good. In either event I agree that the you're not going to gain much from the optics over your SW. What you will gain is vastly superior components and having dealt with cheaper newts I can tell you that it makes a very big difference. I don't have to fiddle with things. I don't have to trouble shoot. I unpacked the scope, put it together, collimated, and use it. That's it.
Alan Brunelle avatar
I put the Steeltrack on my 12 inch UNC carbon at TS's suggestion because last year they could not get their recommended focuser. It was an upgrade, I believe.  In any case I have the EAF focuser mounted and it autofocuses very well.  TS has a 3D printed EAF adaptor for the Steeltrack.  They sent me an extra one for some reason.  The image train includes a Baader CC and my ASI071 MC Pro.  Still working out some minor collimation and backfocus tweaks.
Edit:  the Steeltrack allows you to thread or use a dovetail attachment for threading the consumes essentially zero backfocus.  In fact, you gain backfocus if you remove the compression ring.  Solid.
*Please see my post below on the Steeltrack on my UNC 12
R8RO avatar
Reg Pratt:
Thank you, sounds like you are happy with the tube! This is exactly why I am upgrading. I want something that won't fight me at every turn and that I can just set up and leave be. Again I am unsure what focuser I should choose, not completely clear how compatible the one they recommended me are with the ZWO EAF I already have. Will have to look into this more.
Do We really need to buy expensive Binoculars for Astronomy?
Hello and welcome. I'd like to ask everyone here that. Do we really need to buy expensive binoculars for astronomy or not? Since the earlier forum,m I have stated that I will be planning to get a Nikon Aculon 10 50 binocular. I started to look fo...
Not relevant; discusses binoculars, not imaging tubes or telescopes.
Aug 13, 2024
Running list of known CDK 14 issues and fixes
I thought I'd fork off the discussion from the other thread and gather a list of things that a new or prospective CDK 14 owner should be aware of. Although it's disappointing that Planewave aren't shipping better OTAs or fixing known issu...
Relevant; discusses known issues and specs for a specific telescope model.
Apr 21, 2024
Installing Moonlite Focuser on Vixen R200SS
Hello all, this is a dump of all the info I learnt while looking for a replacement to my Vixen R200SS focuser. I began looking for a new focuser because I was running into the limits of the stock focuser with my imaging train setup: a QHY294M-Pro, CF...
Relevant; covers focuser installation and specifications for telescope upgrades.
May 10, 2024
