Looking for advice on planetary imaging with 8" Newtonian
3 replies267 views
Andy Wray avatar
My family and friends would like me to take some images of planets and I was looking for some advice on equipment.  I have an 8" Skywatcher Newtonian with a native focal length of 1000mm.
At the moment I was thinking of:
* The ASI662MC camera combined with a 3X or maybe at a stretch a 4X barlow
If you've done anything like this, I would welcome your thoughts.
I do know that I will be limited by the Dawes limit of my 8" primary and also by seeing conditions (guess I need to learn all about lucky imaging and processing).
Jacob Heppell avatar
Before I bought a Skywatcher 10" quattro, I had an 8" goto dobsonian that I used for a bit of planetary and lunar photography. I used a televue 3x barlow for the extra reach. The camera was my Nikon D7500 DSLR. I was happy with the results I got. I'll attach a couple of examples. Basically I'd take a ~2min video, pre-process with PIPP to get the best frames and create an uncompressed video file from the off-camera mpeg, which Autostakkert then accepted as an input file and create a single image from the best few hundred frames. After that, a bit of wavelet sharpening in Registax, few adjustments in photoshop and job done.
David Moore avatar
Those images are most impressive particularly in the detail. You must have good seeing where you are.
David Moore:
Yes the region around Perth and south west WA has good seeing for a lot of the year.
On an iOptron GEM28, for use with planetary/lunar photography what would be the largest scope you would put on it?
I have an iOptron GEM28 which I use with a small 5" newtonian and imaging train (ASI533 camera, filter wheel, OAG, guide camera) and this is working fine for astrophotography. I can guide around 0.50" RMS constantly and 600-second exposures...
Discusses planetary imaging equipment setup similar to your ASI camera configuration.
Sep 5, 2024
