Advice on my results with an Edge8 hd on M27 unguided.
9 replies595 views
Redhatman avatar
Hi I have been dabbling in astrophoto for about 3 years now
I have had moderate success with WO refractors and zwo equipment with some images I have quite liked. I have struggled with the step up to long focal lengths. I'm also in a new job and living on a house with building work going on so not imaging often at the moment.
I deforked a second hand cpc edge 800 a few years ago and have struggled with it for imaging since.
At full focal length I find my OAG often struggles to find a star even with a bigger guide camera, autofocus and focus in general with the mirror was difficult.
I have decided to give it one last go before sticking with refractors as I'd like to capture some smaller objects.
The Baader diamondtrack SC focuser works well but I'm concerned that back focus is a bit short as I cam't bring my oag to focus . The main focuisng is a lot better and works well with a ZWO EAF now  (there was a lot of backlash and hunting with the mirror focuser)
The night was quite clear but there was quite a bit of high and wispy cloud,
This was my result with RGB filters (about 50% subs were rejected ) :  30sec subs
M27 first attempt with 8edge and baader diamondtrack focuser
https://astrob.in/j0vjay/0/
Is the banding from cloud artefacts or my battered scope? Is the lack of sharpness a focus problem or is it as good as I might hope from the seeing that night?
Do you think it's worth persevering trying a larger prism OAG etc or should I stick the lot on astrobuyand sell!
I appreciate any feedback and advice on my image and setup.
Many thanks
Sam
It looks like isn't well collimated and obviously 30s is a bit too long for your mount, or so it seems (oblong stars). So focusing with a not well collimated scope could be the issue with the poor focus. Tis said, you are trying to image at around ~0.4"/px. That is very very adventurous to say the least. You should have binned at the very least with much better hopes to get the focus right. The banding is due to your imaging rig or processing artefact, hard to say without the raw files. I suppose AB&S is a tempting option…
Kelly Wood avatar
Hi Sam,
I've found with my EdgeHD 8" that a reducer helps a lot with both OAG and imaging in general. F/10 and 2000mm focal length is just brutal until you get guiding sorted out. I also ditched the auto-focus for a while to concentrate on other things. I found my focus staying pretty good throughout my sessions... what I really needed was to get my guiding fixed and within my pixel scale (which even with my .7 reducer requires guiding at around .5" RMS for good stars at my pixel scale unless I'm binning). That said, when I was struggling at the outset with the OAG, I went to a cheap Svbony guidescope for a while and shot at 2x2. Best guiding I could get with that setup was about 1" RMS, but at 2x2 was within pixel scale, and I was getting some okay results on small targets. I'm now back to using the OAG (Celestron's) and with the ASI174 mini can usually find good guide stars. Guiding is now .5" RMS or below... but even then took PHD2's guiding assistant to tell me all the different ways I had my EQ6-R set up wrong. And, of course, polar alignment is pretty clutch.
With regard to your picture, I think that's a solid effort on a difficult scope and a difficult target. If you're shooting a f/10 (or f/7 for that matter), what you need is more time on the target and good guiding. Planetary nebula are tough, especially that one, and 1/2 hour is not much time on such a dim target. I'm actually impressed you got that much detail in that little time. I don't think your banding is all that bad, actually. But I've found that getting flats right is key to the EdgeHD scopes. You might move to some brighter targets. I've started going after detail shots of large emission nebulae with the EdgeHD, and it's been pretty fun.
Anyway, hope this helps. Don't give up on that scope. I'm still just learning the ropes, but there are folks getting some pretty amazing shots out of them. My efforts are improving, but I'm still on the learning curve.
Good luck, and CS,
-Kelly
AstroDarkSky avatar
I can relate to a lot of your situation. I have an EdgeHD 9.25 that I bought about 6 months after starting the hobby. I could compare it to a WOGT81. I literally had a love/hate with the Edge for 12 months. Couldn't get star shapes to look right, all images seemed really soft, star elongation etc.
Problem #1: I paired it with a CGX. I know many people have had zero problems with these mount, but mine was/is terrible out of the box. Took experience and comparing it to another higher quality mount to realize it was a quality control issue and no amount of hypertuning met my expectation.
Why it matters: I see star shapes elongated in the same direction which is usually a tracking or guiding issue( orcombo). Can be the mount or problem #2 below.
Problem #2: I messed with the Celestron OAG for a long time and switched to a ZWO large OAG. ZWO has a screw on connection vs. the Celestron thumb screws which have a bit of variability in tension, but it may not have been my problem. I think I also have issues with the .7x reducer and ditching that solved a lot of issues. Native focal length is consistently reliable for me.
The main fix: As part of this experiment, I found that bin2 for the guide camera and especially a large prism AND a large pixel size guide camera (ASI174) worked great. I never am at a loss for finding a guide star. Just be aware that the shape of the guide stars may never be perfectly round due to the offset of the prism. Experience will tell when the guide stars look good enough and just go with it. The final image will be ok. Try to get a guide star that is more towards the center and avoid the extreme corners.
Problem #3: I literally spent a year trying to get my Edge to 'work'. I was about to give up and go with the reliable refractor full time. I had dumped enough money into adapters, Hotech laser collimator etc. that I tried one last thing. I sent it back to Celestron for cleaning and alignment. It came back in perfect condition. Bob's Knobs may have been an issue, but what I found made more of a difference was… the mirror lock knobs! If I tighten them too much, I get coma. The factory had it in this semi tight state and when I reproduced their tightness, the star shapes were good. I also heard less of a creaking sound when moving the focus knob. Even when the locks were completely loose/off, the mirror was binding on the shaft and audibly popping into alignment. I think they regreased the internal shaft.
So after all that smile - short answer: Large prism OAG, large pixel size guide camera(5.86) bin2, double check guiding because if it is constantly correcting one extreme to the other due to your guide star issues, balance, etc… it will make the whole image soft. Seeing makes long focal length scopes softer anyways, but it shouldn't be super soft. Oh and set it and forget it with mirror locks and then using a moonlite focuser for fine tuning focus was a major game changer for me.
Redhatman avatar
Thanks so much for the feedback.
I'm relieved to think that I might be able to get some good images in time.  I think putting the reducer back on is the way to go next Kelly has some really nice sharp 8 Edge images with the reducer.
A bigger prism for the oag  might also be good  but I think I'll give it a go with the equipment I have already.
Thanks for the encouragement , I will try and get some more imaging time in again soon to give it a go.
Best wishes
-Sam
Cosmetatos avatar
Hi Sam,
there is more potential in a C8 - a view on images on astrobin will convince you. I started my astrophotography journey last year using an old C8 on a super polaris mount from the 90s. The initial results were poor - DSLR, no guiding, stock focal reducer with horrible aberrations, etc. Slowly and carefully I have added the correct peripherals and finally I just got a first image of M27 with just 1 hour exposure from bortle 8-9 for which I am pleased with (and I still have a long way to improve - I still need to improve my collimation and tilt - along with processing skills!).
In my opinion you need to fix your guiding as a priority.
There are several ways: Either get a good guide scope (60mm aperture), or try to get the OAG to work. I struggled for ages with my old celestron OAG, until I bit the bullet and got a Starizona corrector for my C8 (not sure if you need one for EDGE - but maybe get the focal reducer), and a ZWO OAG. This way, I have nice tight stars even at the OAG and I ensure the correct focal distance for my camera + guiding eyepiece to be at the same focus.  (side note: my mount has significant DEC backlash and calibration was close to impossible - I now ensure that (i) the calibration steps movements are large, (ii) I assume DEC orthogonal to RA, and (iii) if PHD2 callibrates by moving north first, I make sure the last movement in DEC before calibration was North).
If you are shooting from the city you need a good light pollution filter.
https://www.astrobin.com/1ibcf3/
Redhatman avatar
Thanks so much for the reply, that's lovely detail  in the hydrogen, I'm definitely going to put the reducer on and try again when I next see some clear sky.
I agree that getting good results with an SCT is a labour of love, thanks for the encouragement and inspiration I think you may have saved my battered old 8 Edge from a trip to the recycling center!
-Sam
Respectful Supportive
Jacob Heppell avatar
I always felt like an 8" SCT was stuck between two worlds. Kind of needs more aperture and focal length for planetary but way too slow for deep space objects. Yes a reducer can help but if your plan is to focus on taking pretty pictures of deep space objects then a fast Newtonian is the way to go (8" or larger, F5 or faster). For those who like to image galaxies, I see large RC/CDK (minimum 10") style scopes being used. There isn't really a "wrong" scope per se but each format has their niche where they really shine.
Redhatman avatar
The other problem with an 8 edge is it's a bit small to balance, I'm concocting all sorts of weights to fit the losmandy bar to try and get it to balance, it's quite a lot to hang off the end once you add a focuser.
I'm going to persevere though.
Thanks for the replies.
AstroDarkSky avatar
Balance is annoying with these scopes sometimes. Two options that made life so much easier for me was
A counterweight at the front - https://www.admaccessories.com/product/dcw-s-d-series-counterweight-with-3-threaded-rod/
-or-
And just recently ... this has worked AND is useful without just being a dead weight- The new Celestron aluminum dew shield (not the flimsy soft side ones) - https://www.celestron.com/products/aluminum-dew-shield-with-cover-cap-8
[RCC] Heart Nebula
https://astrob.in/i93k2x/0/ This is my first attempt in deep space astrophotography. I could not make my guider work - it was causing star trails. Unguided shots seem to work OK - so just went with that. First time using this gear - so had lots to le...
Author used unguided shots successfully; this post shares unguided imaging results and advice.
Jan 31, 2021
Starsense Autoguider Mirror Flop(?)
My first post on Astrobin! I was wondering if others have experience or thoughts that may be helpful. I have been using the Starsense Autoguider on my Celestron 8SE for a couple of months now. So far it has worked well-ish. For the 8SE, it has a smal...
Starsense Autoguider Mirror Flop(?) — addresses guiding issues with long focal lengths.
Sep 16, 2024
