Your opinion please!
11 replies504 views
TimothyTim avatar
Hello;
I’ve been doing Astrophotography for around two years now, and I keep on working on my technique and believe I’m improving, but I definitely could use a bit more of constructive criticism. This image was taken from my backyard I know I have a bit of a coma issue using Orion Reducer which I already ordered it’s replacement TeleVue Flattener Reducer.
https://www.astrobin.com/e2iou8/B/
Thank you in advance!
Alessio Pariani avatar
I think you exceeded in raising contrast (background is way too black and highlights are totally overexposed). If you have it, try raising clarity (instead of contrast) on Photoshop Camera RAW filter. This will give you the same tridimensionality without burning highlights smile
TimothyTim avatar
Alessio Pariani:
I think you exceeded in raising contrast (background is way too black and highlights are totally overexposed). If you have it, try raising clarity (instead of contrast) on Photoshop Camera RAW filter. This will give you the same tridimensionality without burning highlights 8)
Thanks I’ll look into that. Never tried playing with Clarity in PS before.
Die Launische Diva avatar
I agree with Alessio. Try to reduce the contrast between the sky and the Soul. This will reduce the brightness of the Soul and in that way you'll be allowed to use less noise reduction.
TimothyTim avatar
Die Launische Diva:
I made a bit of update based on that, can you check and let me know?
Die Launische Diva:
Yes, I think it is towards the right direction.
Definitely the right direction!
the nebula is ok now.
Remember that background should never be so dark.
Use a delicate stretch after stacking to avoid much boise comes out.
If you need more signal, get longer subframes. If you need less noise, get more subframes.
You can share your master light with us to get further info and an alternative version processed (help much to understand which are your photos limits)
Supportive
TimothyTim avatar
Alessio Pariani:
Definitely the right direction!the nebula is ok now.
This is the XISF of the SHO I have with SCNR and Cropped: http://tim.bu1.sharktech.net/IC1848-SCNR.xisf
A little about my process after stacking:
PixInsight:
Background Naturalization
Cropping
SCNR Green
Extract Luminous
Apply Deconvolution Process to Luminous
Multiscale Linear Transformation Noise Reduction
Linear Stretching of both Luminos and RGB
Noise Reduction of RGB TGVDenoise or ACDNR
Combine L with RGB
Morphological Transform and MMT Star reduction with Starmask
Test HDRMultiScaleTransform Result
Test LocalHistogramEqualization
Curve adjustments RGB and Saturation
PhotoShop:
Despeckle
Reduce Noise (test)
Adjust color intensity
Adjust curves
Test additional smart sharpness
Hue/Saturation
Color Balance
Topographic avatar
I think all three images are interesting as they highlight different aspects of the subject. This tells me you have some good data there…that is the really important thing. Post processing is subjective, play and follow your instincts!
TimothyTim avatar
I think all three images are interesting as they highlight different aspects of the subject. This tells me you have some good data there...that is the really important thing. Post processing is subjective, play and follow your instincts!
Thank you I appreciate that. I’m just looking for pointers to up my game, bringing my image quality a bit higher.
Victor Land avatar
Just out of curiosity; why did you put this under Electronically Assisted Astronomy?
TimothyTim avatar
Victor Land:
I have the whole setup in my backyard with a computer mounted on the OTA. I remote in and manage the setup and according to what a previous discussion here about this, that fits the EAA category.
[RCC] First attempt at M42 with a star tracker
Hello ! I just finished my first complete workflow using PixInsight with M42 as a target and I hoped to get some constructive feedback on my picture to help me improve my skills in the future I just started this hobby and this picture is from my very...
Seeking constructive criticism on deep-sky object image with processing workflow.
Apr 5, 2021
Looking for a bit of pointers for my Image processing
Hey fellow nerds; looking for some constructive criticism for my M42 image (I know its a common target but I think it’s one of the hardest). Would greatly appreciate your input, thanks in advance! https://www.astrobin.com/0tzdl9/D/
Requesting feedback on M42 image processing and technique improvement.
Dec 27, 2020
Six lessons learned by a professional astronomer in his first six months as an amateur.
Having retired as a professional astronomer and moved to a rural (Bortle Class 3) site in New Zealand, I decided to take up the hobby of astrophotography six months ago. I started with a good knowledge of astronomy, CCD processing, but no kit apart f...
Professional astronomer shares lessons relevant to improving astrophotography technique.
Dec 2, 2020
Hello from New Hampshire!
Hello Astrophotographers! I am joining you from southern New Hampshire. This site was a very exciting discovery. I am looking forward to seeing your work, sharing mine, and improving on my technique, approach, and results. I am currently set up with ...
Working on technique improvement, seeking feedback on astrophotography progress.
Apr 1, 2018
