Imaging drifting even though I’m guiding
8 replies313 views
A. Wegdan avatar
Hello guys,
i hope someone here can help me with this issue.
so my image keeps drifting over time even though I’m guiding.
Here are the details:
CGEM mount with horrible dec backlash and some in RA polar aligned with 4 arc min PA error and a total guiding error of 2
I use a WO Uniguide 32mm and 120 focal length on a side by side setup.
I use a diy modified Logitech webcam c310
When imaging with an asi224 on the native focal length (1500) of my scope the image would drift about half the way of my FOV which is about 6 degrees in about 10 minutes.
I don’t think it’s flexure as the side by side is pretty solid.
It also could be that the guide scope isn’t properly pointing at the same direction.
Both issues I’m aware of but what I want to know is how to calculate it.
if my calculations were correct at this focal length I should have no trailing upto 30 seconds (I could be wrong)
I would love it if anyone here could validate my polar alignment error tolerance calculation and provide me with something to calculate the drift rate change for ever 1 degree variance between the main imaging scope and the guide scope.
and of course any suggestions on how to keep the image in the same place would be great.
For the time being im doing short exposures so I don’t need super accurate guiding I just want the image to stay in one place so I can live stack.
Thanks
A precise PA alignment would allow you to have drifts measured in (few tens of) arcsec/hour. So your drift (degrees/min) means your effective PA is much worse than 4' (which is large by my standards, I aim at less than 30"). The amount of drift depends on where the telescope is pointing at so it is difficult to give precise numbers unless this is also known.
Olga avatar
Hey, I can help you with that. I have been using an EQ3-2 with terrible DEC backlash, a 360mm focal distance guiding scope, and a very weak camera for guiding. What I see is, polar alignment is sure a big deal when guiding on a mount with loads of backlash and a rather not sensible camera.
The best alterative would be adquiring a sensible camera. This alone would solve most of the backlash problem as having a sensible camera literally wont make the backlash happen (most of the times) in the first place. But taking that option away, with what you got, there are some things you can do to improve guiding overall:
1- When guiding, find the brightest star possible to guide with. Something i noted on my experience is that, whenever a almost transparent cloud passed by, my guiding would become really unstable and completely lost. Also, whenever I had a dim star as the guiding star, the program would think it was noise and catch on other white pixels and start guiding on noise. That would deliver me a low error, but obviously it was as if guiding was tuned off. If you only have dim stars in your field, tilt your scope until you can find one.
2- Increase the range the program will seek for the star. With a low sensibility camera, it is good to increase that number whenever you find a bright star. But make sure to not put that range between two stars, as the program might "jump" among them and make a complete mess. Just keep in mind to increase the camera contrast so you won't catch on noise as a guiding star.
3- As your main scope has 1500mm of focal distance, i usually use a tip i heard somewhere. It goes like this: you divide your main focal distance by 5 and this will be your guidescope ideal focal distance. In your case, I would use at least 300mm for proper guiding without overloading the weight capacity.
4- Make sure your mount doesn't have any loosen up screws. Specially the ones who attach it to the tripod or keep the polar alignment in place. Even the polar scope screws ust be tightened up, as any movement can worsen your guiding process.
5- Another thing that might work depending on your case is slightly unbalancing your mount RA or DEC to the opposite side of your backlash error. This way, the backlash MIGHT be balanced. For some mounts it works, for others (mostly), it helps a bit, and for some it worsens the problem. Keep in mind that the imbalance is minimum, think about it as leaving some momentum on the opposite side of the error.
6- There are some screws that will be responsible for keeping your mount's worm gear in place. I am no expert on the CGEM mount, but a quick research will teach you how to find them and fine tune them. On my personal case, finding the sweet spot beetween tighteness and looseness to release part of the backlash took me a whole month of try and error. It's a boring and irritating process. But it is so much worth, as you will get rid of a HUGE part of the backlash.
7- Unfortunately, mounts are not perfect. The more gears you have, the bigger it is, the less backlash you will have. But for EQ3s and EQ5s it's much more difficult to not have this problem. So, your guiding should not let the backlash happen at all, but sometimes, for any reason inside the gears, it might happen. So accept the fact that you might not get all pinpont frames, try to reduce your exposure time (specially if youre under light polluted skies), and remember that quality is better than quantity.
8- Last resource, if you try to adquire a sensible camera, like the asi 120 mini, and if you have tried every method above and you still have backlash and can't guide, it's time to take your mount to fix. I had friends who owned the CGEM mount and they'd have incessant problems with guiding on it, gigantic erros, even worse than my EQ3-2. So, keep in mind that you might need to open it yourself if you have the experience with gears and bearings and try to lubrificate it all over again, change whatever is needed, watch out for guides on how to fix it. But this is a last resource; i'm sure simple measures might help you to get 1'00 eror or even less. Ater trying all of the measures above, I could be able to get a 0'5 guiding error most of the times when guiding on a bight star.
This process is tiring, but I'm sure some of these tips can help you.
Clear skies,
Olga smile
A. Wegdan avatar
My calculations could be off, the 4' i got from PHD2. I will try to fix it better, though i was under the impression that anything under 10 PHD2 can sort of mitigate.
Regarding the drift, I'm terribly sorry my FOV is 0.12 not 12 its actually (0.19° x 0.14°), so that's 0.6 degrees approximately every 10 minutes.
The guide scope is roughly pointing in the same direction, but of course the it has a 1.77° x 1° FOV. So when when i have Jupiter Centered on the main imaging camera its on the top right corner of the guide scope showing with all its moons . In this particular case of jupiter being centered the FOV is 0.06° x 0.05°
Below is the image from my guide scope.
I hope this makes more sense now.
Ill try to fix my polar alignment better but the screws on the CGEM are quite clumsy.
A. Wegdan avatar
Clear skies,
Olga
Thanks Olga,
Already working on getting some new gear, I am actually imaging with my proper "guide camera" but you gotta work with what you got.
I do an east heavy balance to mitigate the RA backlash and i did maintenance to the RA. I'm unable to do the DEC yet its more complicated.
To avoid trails I do super short exposures 1 - 90 depends. What is weird though is i get less drift when im doing unguided. The only reason why i want the guiding to work is for dithering.
Great images by the way
Thanks
Bob Lockwood avatar
Hi Ahmed,
Not sure if this helps as I don't think you mentioned what software you use for Acquistion.
I use Maxlm dl, and when you are guiding you can set the aggressiveness from 0 to 10 depending on the seeing for how fast the guider reacts to movement. If I set it at 0, it's still guiding but dose not make corrections, and it will still do a dither after each exposure. Maybe this is something you can do as well.
Concise Supportive
A. Wegdan avatar
@Bob Lockwood
im using sharp cap pro.
I never tried setting the aggressiveness to 0, it’s usually at the defaults for phd2.
If you use sharpcap pro you should be able to use it to nail down your PA. Or the drift method, which I used to use without any camera, just a guiding EP. In fact it is probably the most accurate method, with eiether EP or camera. I also have a 30 years old Celestron CI-700 which is just pathetic in terms of backlash and poor adjustment screws yet I can manage to get a very refined PA, of the order of 30". Good enough to keep Jupiter in 640x480 frame at 8 meters FL for 30 minutes or more. So you can make it too.
Supportive
A. Wegdan avatar
@andrea tasselli ill give that a go i just bought the pro version yesterday so haven't tried PA with sharp cap yet.
will give it a go and see thanks
Guiding on an 8" SCT for long exposures.
I have been trying to use an auto-guiding scope (400mm FL) with ASI120mm mini camera on my NexStar 8se. I get good polar alignment and my guiding error is consistently less than 0.5. In my imaging sessions, I use a 0.63 focal reducer and so my effect...
Addresses trailing issues despite guiding; directly relevant to your problem.
May 22, 2021
17 things I did during the last year to greatly improve my astrophotography
17 things that I did in the last year that improved my astrophotography. Hi, I am an amateur astrophotographer. I have spent about 10 years doddling with it, even taking a 3-year break during the pandemic due to work commitments. I came back to it in...
Improving astrophotography techniques may address guiding and image drift issues.
May 22, 2024
« How to ... ? » : taking pictures of the ISS
Hi fellow astrophotographers, I know the ISS is not a deep sky object nor a planet…. but it seems to be really a fun project to capture it ! That being said, my skills are really limited, and I am just starting to get descent images of deep sky...
Author has CEM70 mount; guiding issues relevant to satellite tracking challenges.
Feb 5, 2021
Dual setup: side-by-side vs one-on-top
Hi guys. In the next few months I'll move my setup in a remote hosting astrofarm here in Italy. At the beginning I thought of installing my FRA 400 with the 10micron GM1000, to have greater ease of use and to become familiar with remote imaging. ...
Discusses side-by-side setup configuration relevant to author's dual guide setup.
Aug 18, 2024
