I just read on the 3nm thread that StarXterminator does a better job of removing stars to StarNet. Does that comparison include StarNet2?
Thanks
Thanks
The new version works both on linear and non-linear images. You may be interested in these videos:
(2) StarXterminator and More with Russ Croman - YouTube
(2) New StarXterminator 2 with AI 11 for PixInsight! - YouTube
Both are a bit promotional but still interesting and impressive. Obviously the software won't work equally well on any image. What I like is the attitude to work on improving it further without extra cost for those who already bought the software.
Clear skies
Wolfgang
Maybe I expressed myself poorly. The new version works on linear and non-linear images without active choice of the user. You just apply the software to your image whether it's stretched or not. Russ suggests to apply it to the unstretched image in PixInsight since any sort of processing may alter the characteristics of the stars and may make detection of stars more difficult for the algorithm.
Clear skies
Wolfgang
Alan Brunelle:
Good to hear that. It's ability to work on linear objects was most important to me.
Dale Penkala:
Even with my Ryzen 9 it takes a little extra time then the previous version
Andy Wray:Dale Penkala:
Dale, do you not have an Nvidia graphics card in your processing PC? If you do, it makes a huge difference to enable GPU acceleration.
Dale Penkala:Andy Wray:Dale Penkala:
Hello Andy,
Yes I’ve got a 3060 12gb GPU with 94gigs of DDR4 ram. I can’t believe how much fast this machine is from my original i5. I’m really glad I have it now because with the scripts and other Pixel Math expressions in PI it sure makes a difference. I really like the new version of StarXTerminator and I’m glad I now have the computing power to fully utilize this plugin for PI.
Dale
Andy Wray:Dale Penkala:Andy Wray:Dale Penkala:
Hello Andy,
Dale
Just checking: what I was asking is have you enabled the GPU acceleration? It's not that straighforward, so was just checking. It should take about 5 secs on that GPU.
Andy Wray:
Just checking: what I was asking is have you enabled the GPU acceleration? It's not that straighforward, so was just checking. It should take about 5 secs on that GPU. I have a 2060 and a much slower processor and it takes 8 secs.
Dale Penkala:Andy Wray:Dale Penkala:Andy Wray:Dale Penkala:
Hello Andy,
Dale
Hi Andy,
I the only thing I have done on is the bench marking with PI and added 6 swap folders. How would you “enable” the GPU acceleration?
Dale
Andy Wray:Dale Penkala:Andy Wray:Dale Penkala:Andy Wray:Dale Penkala:
Hello Andy,
Dale
Hi Andy,
Dale
I did it ages ago, so didn't make detailed notes, but I followed something like this: https://www.williamliphotos.com/starnet-cuda
Dale Penkala:
Ahh ya I tried to get that to work with my i5 and I had to make an account that stated I was some sort of developer so I didn’t do it. I believe there is a YouTube video on how to do it that I followed and I wasn’t comfortable making that statement. I really would like to have done that however. As you have mentioned its really soposto make a heck of a difference!
Dale
Alan Brunelle:Dale, do you not have an Nvidia graphics card in your processing PC? If you do, it makes a huge difference to enable GPU acceleration.
Andy,
I may have to look into video card acceleration for StarXTerminator. I used it for Starnet, and it was amazing. But StarXTerminator did not use it, or at least use it last year when I was still doing imaging.
But what is clear is that my CPU processors are now being pressed into use with StarXTerminator. It was very easy to tell when Starnet switched to the GPU, because I could easily hear the different cooling fans switch over from the CPU to the GPU. If I can get StarXTerminator to do so, I should be able to bump up my overclock on the CPU again.
But either way, it's still very doable. Just nice to get some value out of the damn GPU!
Alan
Jonny Bravo:
Wow... I might need to build a processing PC... I use my 2019 8 core i9 MacBook Pro with the Radeon 560X and I measure the process time in minutes
Alan Brunelle:
