Sw esprit 100ed flattener distance
6 replies245 views
Themis Karteris avatar
Hi i want some help to find the right distance. I use QHY9 + Starlight xpress FW+ OAG Starlight.
The optical window from qhy9 removed.
Someone with the same setup for help!!!
thanks  smile smile
Juan Filas avatar
Hi, is 63mm
Victor Van Puyenbroeck avatar
Juan Filas:
Hi, is 63mm
Interesting, the manufacturer states 55mm. Why is the optimal distance so much larger?
Marcelof avatar
The distance is 55mm if you use the adapter that comes attached to the flattener or 63mm if it is removed (page 8 of the manual, available on the SW website).
The point is to cover exactly this distance taking into account the proper distances of your equipment:
Backfocus camera + FW + OAG + The filter itself* + adapters = 55mm
*for the filter a distance of 1/3 of the filter width is usually calculated.
Manual:  https://www.skywatcherusa.com/pages/support-center
Stratos Sinathis avatar
The right distance from the back of field flatterer to your camera sensor is 55mm. +-1mm will be ok too.
Hi i try to fix all the system with 55mm but it's not possible. I must take off the oag and i don't want it.
Now i have 58mm. I will try it at next new moon and i will inform you for the result with image!!!
Thanks all smile
Hi I do some tests with 58mm distance and is fine. It has a little in corners but is very small!!,
Thanks
Need help with OAG optical train setup
I’m adding auto-guiding for the first time (OAG – ZWO) and have already had a couple optical train derailments and hoping for some help getting back on track. Right off the bat, I managed to bind a couple of the extension tubes and ruin both trying t...
Author has OAG setup questions; candidate discusses OAG optical train configuration.
May 2, 2021
Omegon off-axis guider w micro focus
Hi all I am investigating which OAG to invest in. After some reading I understand that I should find an OAG with - large enough prism - focus mechanism for guide camera -mechanical robustnest (general requirement) In combination with a suitable guide...
Author seeks OAG advice; candidate discusses OAG selection and focus mechanisms.
Feb 2, 2021
What OAG Guide Cam resolution needed
Hi folks, I have two scopes that I plan to use in the future. Which one I choose will depend on the target. My main scope will be the Explore Scientific MN-152 Comet Hunter for nebulae and wider fields. The second one is a TS Photon 10" f/5 that...
Author uses OAG with camera; candidate addresses OAG guide camera considerations.
Mar 22, 2021
