I'm just scratching my head about something and would like to hear your feedback on it. Although I am working with a specific scope, I believe my inquiry is independent of that and so I haven't placed it under the matching equipment.
I have a William Optics ZenithStar 81 doublet and the recommended reducer (Flat 6AIII, despite the name, it has a 0.8 reduction).
I'm using the scope with two cameras:
- a monochrome CCD with a 1" (i.e. 16mm) sensor diagonal. Filters with thickness in the range of 1mm and 2mm (depending on brand)
- a APS-C sized Canon DSLR
I believe that I've dialed in the backfocus "correctly" (or sufficiently) for both cameras: on-axis stars and stars in the corner are in focus simultaneously (as far as I can tell from the Bahtinov mask) and star shapes look nice.
What confuses me now is: the focuser has a scale (mm unit) and for the smaller CCD, the focuser is at position 21mm and for the DSLR, I am close to 24mm. That's a difference of roughly 3mm. Shouldn't the focuser position be the same for both cameras if backfocus is "identical"?
Of course, the CCD operates with additional filters and probably there's more protective glass in the CCD than in the DSLR. But in my opinion it would just require additional spacers yielding the same "effective" backfocus, wouldn't it?
The only explanation that I have is that the CCD is not as accurately placed as the DSLR since the CCD is smaller and can probably be more off w.r.t. to backfocus than the larger DSLR?
I guess the approximated deviation from a flat field would be proportional to the squared distance from the optical axis?
Since the diagonals have a ratio of about 1.7, the residual error on the small 1" sensor (due to my measurement accuracy) would scale up to nearly 300% residual error on the APS-C.
From raytracing simulations my impression is that small changes in the backfocus position (if we'd just look at getting into focus on-axis) leads to much larger changes in the distance between objective lens(es) and reducer or in other words: position of the focuser. Is that correct?
Björn
Björn
