Simple way to take flats
8 replies341 views
Andy Wray avatar
I've found the simplest way to take flats with my 8" Newtonian is:
* I use an A3 LED tracing pad bought from Amazon (about $35)
* I put two white vests/T-shirts between it and my OTA (about $10)
* I set the tracing pad to its lowest setting
* I use a black shower cap to stop light leaking into the bottom of my scope (about $8).  FWIW:  that black shower cap has been the best investment I ever made as it makes taking darks a doddle as well.  My scope does suffer from light leaks from the back end.
* I personally use Nina's flats wizard to take the flats, although it worked equally well with APT.
It's not exactly elegant, but works very reliably and didn't cost much.
I know I could do sky flats, but being able to control the LED's panel brightness makes it so much more repeatable.
Well Written Helpful Engaging Supportive
Rouz Astro avatar
You can control the brightness with something like the Spike a flat USB controller, It worked on those amazon panels.
The dew output of something like the Pegasus should work as well.
Those panels work but are not 100% even, in most cases will work fine.
Rouz
Frédéric Auchère avatar
One way to even out possible non uniformity is to average many flats and shift / rotate the panel in between (or during) exposures.
Frédéric
Die Launische Diva avatar
Frédéric Auchère:
Frédéric
This, and use drawing paper sheets instead of a T-shirt
Andy Wray avatar
Frédéric Auchère:
Frédéric
Interesting thought ... I might try this, although, to be honest, I haven't seen an issue by the time you've added a couple of t-shirts
Arun H avatar
Die Launische Diva:
Frédéric Auchère:
Frédéric
I use the drawing paper method. In addition to acting as a diffuser and improving uniformity, it dims the light more than I can with just the LED panel controls and allows me to use 4s exposures to put myself in the linear regime of my sensor. Just add as many sheets as needed for the particular filter! Lum filters can take as many as 8 sheets, so I keep a stock of them.
Die Launische Diva:
Frédéric Auchère:
Frédéric
+1
I also use translucent paper for added diffusion and dimming. The shifting / rotating routine is an extra layer.
F
Ron avatar
I do the exact same thing with one addition.   You might consider using embroidery hoops to keep the T-shirts taut and unwrinkled.  They work well!
Ron
Andy Wray avatar
Ron:
Ron
I had embroidery hoops, but having added a new (relatively cheap) low profile focuser I found I was forced to add my ZWO EAF so that it gets in the way of the hoops.  I will be purchasing a better focuser that will allow me to flip the EAF to the other side where I used to have it.
To be honest:  the hoops did look good, but it's no real hardship without them.
Dark Filter for Making Darks, Making Flats Remotely
Hello! I am considering putting a telescope in a remote hosting site. I am thinking about many details, including how to make darks and flats. I could get a Moravian camera that has a mechanical shutter, but it has the same sensor as the ASI6200 whic...
Remote hosting site needs flat/dark frame procedures; similar DIY approach applicable.
Apr 6, 2024
Newton Flat Problem (Ring pattern) Light pollution a cause?
Hello guys, I've already read a lot of forum post about this topic. Usually the problem apears to be reflections inside the tube, light leaks, sometimes the corrector sticking inside of the tube or a GPU causing wierd stuff. Some people are doing...
Light leaks and reflections directly addressed; shower cap solution relevant.
Mar 13, 2024
How to take Flats that work? (Canon EOS M50)
Hi all, Been taking DSO photos for about 6 months now, and I still am not getting great results from my flats. My images still have donuts which are hard to remove in post-processing. Does anyone have a technique that would work better? How I do it: ...
Struggling with flat frames; author's practical LED pad method offers solution.
Mar 17, 2024
