I've learned from bitter experience that adjusting your secondary mirror on a Newtonian when you don't know what you are doing is a big mistake
To any newcomers, I would suggest not touching it for a couple of years if you can help it. It is very sensitive to adjustment and getting it wrong will cause all manner of issues.
It moves in so many degrees of freedom and as such you can lose control of it quite quickly.
I have learned from my mistakes with it and am now happy that I know how to control it, however it is not for the fainthearted.
[Update] I should have said don't tinker with the middle screw that ends up with you adjusting the angle of the secondary and the height up and down the tube; they should have been set quite well at the factory. The other three are fine to use as you can learn how to align the secondary to the primary etc..
