David Moore avatar
I have just tried Deconvolution for the first time on Hickson 44 and got smaller stars and more detail in the galaxy group. However background noise levels increased significantly and the brighter stars have red and blue blotches. I feel that I have just opened a door into something really complex. What have I do wrong and is it used a lot? It seems to be really useful if used carefully by someone who knows what they are doing. I followed the steps in the Inside PixInsight book by W.A. Keller. It seems to be an iterative process.
kuechlew avatar
You may check this thread for further instructions:
Using Deconvolution in Pixinsight - AstroBin
Clear skies
Wolfgang
David Moore avatar
Thanks I am reading this now and it makes a lot of sense for far.
Tim Hawkes avatar
I think deconvolution relies on objects being represented by continuous functions  - which stars of course are not.  I usually mask stars off from deconvolution (the process tends to turn them into sharp Lorenzian points) and just apply the process to sharpening up details of e.g. bright galaxy cores, nebulosity and planetary nebulae.   The stars are useful though because in PI you can use them to better define a local PSF adjacent to the object you wish to deconvolute.
Deconvolution also only works on areas of high SNR  so it is best to mask off fainter areas to avoid strange effects.  It is definitely a process well worth applying though to the right kinds of objects --  it has been transformative for recovering fine detail from some of the bright smaller planetary nebulae.  Although of course - the Nyquist limit still applies -  so it also requires  getting the image scale down   (i have been sampling down at ~ 0.5 arcsec in the hope of eventually recovering detail after deconvolution down to about 1)
Tim
PS noting your comment about coloured blotches ? -   I think that for colour images the process should only be applied to the luminosity  (or  to single colour channels) ?  Getting a bit deeper into the theory    https://www.researchgate.net/publication/2323502_Deconvolution_With_Correct_Sampling
Helpful Insightful Engaging
Tom Boyd avatar
I would suggest checking out Pat Cosgrove's deconvolution tutorials. They are well written and very helpful...
https://cosgrovescosmos.com/tips-n-techniques/using-deconvolutioninpixinsight-part1-introduction
Well Written Concise
