=VIiyi=JLqJ4b=Q4iAWcMoravian G3 16200 Mark II 16 Mpx mono CCD APS-Hcamera is for sale.
Contents of the set:
- Moravian G3 16200 Mk II CCD camera
- Moravian OAG
- Moravian 2" 7 filter wheel
- Astronomik L2 2" luminance filter
- Astronomik RGB DeepSkye 2" filter set
- Astronomik 6 nm 2" Ha-OIII-SII filter set
- Suitcase
- Power supply
- USB2 cable - adjustment platform (also available on OAG)
- spacing rings for precise adjustment of the correct back focus
- installation and control software on pen drive
- User's Guide
more photos: https://drive.google.com/drive/folders/1bFQRT-uIuxQFp0oMLYdaHo0F0NI70qoW?usp=sharing
A reliable, professional 16 megapixel observatory instrument, which is in immaculate condition both externally and functionally. Its cooling makes a difference of more than 40 degrees, it can cool the sensor from 23-24 degrees to -20 degrees at 90% power. I used it gently, up and down with a maximum difference of 2 degrees per minute. I acquired the camera in 2019. I used it with a 200/800 newton telescope (with Paracorr Type 2 corrector), its control is solved on INDI-EKOS and ASCOM platforms, I used it with EKOS without any problems. Thanks to the large sensor and large (6 micron) pixels, it is ideal for scopes with focal lengths between 600-1200 mm, but thanks to hardware binning and 16 megapixels, it can be used up to 2500 mm without oversampling (bin2=4 Mpx and 1 arc second ad at 2500 mm). Unbeatable quality mono camera in LRGB, which - based on the attached photos - can also be used effectively in a narrow band.
Reason for sale: changing to a smaller camera I will only sell the filters separately if the camera is sold without filters.
Price of the set is 3 200 EUR/$
Camera location: Budapest, Hungary
