I've been struggling with my stars ... any advice?
11 replies989 views
Andy Wray avatar
I have really struggled with my star roundness and also lots of diffraction spikes recently.  Below is my best effort to resolve it so far.  I think I am still seeing diffraction spikes and I'm guessing they are from one of my mirror clips.
What do you think is causing the issue?
Daniel Renner avatar
Starspikes comes from your spider vanes, holding yout secondary mirror. if you dont want them you have to buy another type of telescope. And the star roundness dipends on your how good your guiding is, and also the colimation. What does your RMS say in phd2?
Andy Wray avatar
Daniel Renner:
I'm fine with the spider vane spikes; it's the other fuzz around stars that bothers me.  My PHD2 RMS is typically between 0.44 and 0.5 arc secs RMS, although RA is usually about 50% worse than DEC.
Well written
Wolfgang Promper avatar
To me this looks like a slightly turned down edge of the primary mirror.
Usually a simple  cardboard mask  that covers the edge should solve this.
Well written Concise
Tim Hawkes avatar
Hi Andy, looks like just a little bit of mirror pinching to me. Just loosen off the clips slightly I would say. I had exactly the same with a PDS200. Tim
wittinobi avatar
Tim Hawkes:
...agree.
you have to clarify the following...
https://www.astrobin.com/forum/c/equipment-forums/sky-watcher-explorer-200pds/skywatcher-200pds-cant-remove-primary-mirror/
Andy Wray avatar
Tim Hawkes:
I think you may be right Tim.  Unfortunately I've tried four times now to remove the primary mirror and it is jammed tight in the tube.  However much force I apply it just won't budge
Well written
Andy Wray avatar
Wolfgang Promper:
Could it actually be the edge of the secondary?  Using a Cheshire today I noticed that the edge of the secondary mirror was visible and the opposite edge of the mirror was outside the field of view of the focusser tube.  i.e. the secondary was 3 or 4 mm too far down the main OTA axis.  I guess over the years of fiddling with the secondary I had ended up inching it down the tube quite a bit.  I also noticed that the angle of the secondary was not that well aligned (i.e. only one of the 3 primary mirror clips was visible; now all 3 are only just visible).
I guess what I'm also saying is that until today I didn't really know what I was doing with secondary mirror alignment;  it now all seems so obvious.
I don't have clear skies right now, but will take some test flats to see how even the illumination looks now (it was quite lopsided before).
FWIW:  using my laser collimator to align the secondary to the primary centre spot was much easier than before and aligning the primary using it has ended up with a primary that is much more even (perpendicular) in the tube.
Helpful Insightful Engaging
Mike Dobres avatar
Hi Andy
You can take some of the guess work out by doing a collimation check with an artificial star and looking at the interference rings on the inside of focus and the outside of focus.. Issues such as  pinched mirrors, misaligned secondary, and coma are typically identified with this method. In my case I was able to identify heat currents in the tube, as a problem. Fixed by removing the shroud and using a fan.  This is exactly what I was talking about in my response to your use of a laser collimator. That is, adding a star test, even using and artificial star, is an invaluable tool to checking the alignment and performance of a newtonian
There's stacks out there on the web on this. Here's a very useful link to get you started.  Here's a useful link
http://www.loptics.com/articles/starshape/starshape.html
The artificial star I use is the Geoptik https://www.astroshop.eu/artificial-stars/geoptik-new-artificial-star-for-collimation-and-star-test/p,5976
For your 200  ap X 1000 fl scope you only need 17 meters to collimate.  1 km to perform a true start test.  Though, I've found I can detect major defects at twice the collimation distance Neat thing is this testing can be done on a cloudy night
Hope this helps!
Mike
Andy Wray avatar
I'm clearly not quite there with my secondary alignment, but this is better than I have achieved before.  I will keep trying.  I believe it is actually pretty good, but we all want perfect, don't we?
This is what I had before I adjusted the secondary:
and this is what I have now:
and here is what the flat actually looks like:
Andy Wray avatar
Mike Dobres:
My garden isn't that big
Mike Dobres avatar
Andy Wray:
Mike Dobres:
Some folk do it in the street
Reflector star size(s)
Hello everyone. I was wondering what your average star sizes are, or even the best you've ever been able to capture with a Newtonian? The reason is, because I am wondering at what point should I try to give up on the perfection of my collimation ...
Discusses star size issues with Newtonian reflectors, directly relevant to roundness problems.
Apr 8, 2024
Takahashi E-130D Double Diffraction Spikes - trying to identify the cause
Hi there, So, I received my Takahashi e-130d several weeks ago. As is custom to receiving new equipment, I had cloudy skies for a couple of weeks. I ended up taking it out for first light on 04/06/24 (april 6) and noticed the diffraction spikes on th...
Addresses diffraction spike causes in reflector telescopes, matches your specific concern.
Apr 13, 2024
Newt Astigmatism: tilt or secondary mirror?
Hello, I'm struggling to get good star shapes across images from my ONTC 10" F4, specifically around the corners. I tried everything and can't seem to locate/confirm the source of my problems. Some information about the setup: General Se...
Covers star shape issues in reflector optics, relevant to roundness and optical problems.
May 24, 2024
