I have decided I want to have autoguiding in my current setup (Skywatcher 130pds). The autoguider setup I am looking at are:
https://www.bintel.com.au/product/zwo-asi120mc-s-usb3-0-colour/?v=8e3eb2c69a18
and the scope: https://www.bintel.com.au/product/zwo-60280-guidescope/?v=8e3eb2c69a18Only problem is, I am unsure how im going to mount the guidescope to my main telescope. Here is an image of the T-Rings for my telescope:
https://imgur.com/a/8J8nio6
https://imgur.com/a/1uGD5ko
would purchasing another dovetail to go across on the top of the T-rings, then mounting the guidescope with screws work? The dovetail would be: https://www.bintel.com.au/product/skywatcher-dovetail-bar-20cm-long-metal-extrusion-and-metallic-green-anodized/?v=8e3eb2c69a18 which is the same as I have on the bottom of the T-rings already to mount the main telescope. I realize that the two holes in the Dovetail bar are very close together so I would possibly have to drill a new hole or two.
Is this the only viable solution to mounting this guidescope setup or is there any better way I could go about this?
If all else fails then I may just settle for the Orion Mini https://www.bintel.com.au/product/orion-mini-50mm-guide-scope/?v=8e3eb2c69a18 and mount it to the preexisting guidescope mount.
