Marc avatar
I am currently using the iGuider built into my CEM70. Cannot say I am super happy yet.
Two things I have not solved:
1) In PhD2, on startup, the preview is at gain 0 and super bright. When I push it to full gain, I start seeing stars and the background is darker
2) When I do the above step, the image shows severe vertical banding
These two things seem a bit "off" to me. I do get acceptable guding with this, in the 0.5" range. Still… Is someone else dealing with this; and is there perhaps a (permanent) solution? I did upgrade the firmware last spring; so it's at least not old "stock" firmware.
Marc
Kash avatar
Did you try redoing your dark library ?
Marc avatar
Kash:
Yes, a couple of times now
Andy Wray avatar
I don't own an iGuider, but just in case:  Does it have a native driver and an ASCOM driver.  If so, have you tried both?
ASIair + off axis guiding
Hi, has anyone tried using the ASIAIR PRO and off axis guiding? I'll be buying a 12" RC (FL 2432 mm) so Iguider on CEM70G not ideal at all. Any pointers appreciated Ivan
iGuider/CEM70G issues directly relevant to author's mount choice.
Nov 25, 2020
