Benjamin DeHaven avatar
I am trying to figure out if my data is bad or my editing process is bad (or both). I'd love some feedback. Attached you will find my best edit, it is about 3 hours of data with a Nikon D850 unmodded and a Nikon 200-500mm  at 500mm f5.6. I use 5 minute exposures at ISO 400. I know galaxies aren't supposed to be green... I have the trial of Pixinsight but am having trouble figuring it out so this is edited in good ole Photoshop. I see these beautiful Andromeda's on here with gorgeous blues and peaches and I for the life of me cannot get my data to do that. So basically, where do I need to improve the most and what can I do?
M31 - Andromeda Galaxy
This is my original, stacked but unedited if you feel like taking a look or even editing it...
https://drive.google.com/file/d/1jQI2CgHzvh-xA-hfyx9nQIt1FKwFxYY7/view?usp=sharing
Benjamin
Respectful Engaging
Shawn avatar
PixInsight's SCNR does a good job removing the green cast.
https://www.chaoticnebula.com/pixinsight-scnr/
Michael M avatar
To remove the green cast you can use SCNR in pix. I’d also recommend hue-saturation adjustments. Im sure they exist in pix
Ian McIntyre avatar
This method for color calibration on Shawn Harvey's video works great. Start at 4:03
https://youtu.be/Xl036NZ3Eoc
He also uses SCNR later in the video.
Andy Wray avatar
I had a quick bash at improving the colours.  Photometric colour calibration in Pixinsight, a 60% SCNR green noise reduction and some hue and chrominance tweaks in curves.  Your data looks pretty good from what I can see, so maybe just a bit more time spent on colour calibration.
Well Written Helpful Concise Supportive
That's a correctly coloured image in the main, broadband images of M31 should show a yellow-green cast if you use standard umodified DSLR (NIKON) and use photometric colour balance in PI. You would need to tweak the hue curve in PI to remove the green cast (but do not expect those H-alpha reds to show!) and please, do not use SCNR, that is for the background only. I might try to give it a more pleasing colouring if I find the time later on.
Helpful Insightful Respectful
I had a quick look and apparently the image you posted isn't calibrated, certainly not flat-calibrated. You're not going very far without proper calibration I'm afraid.
Well Written Concise
Thats odd, I took some flat frames and threw them into the mix in DSS. I assume that's what you are referring to. Still a beginner so forgive me if I misunderstood you. I will take more flat frames next time. Thank you.
Benjamin
Steve Cooper avatar
I tweaked the color some in Pixinsight then used the Photometric color calibration tool. Also used the HDMR Multiscale Transformation tool with a mask to bring out the dust lanes more.
Here is my latest attempt based on what I could do in Photoshop with the Pixinsight advice which I couldn't figure out how to implement. I'm a total noob in Pixinsight...
How do I get from where I am to an image which is just fantastic like:
https://www.astrobin.com/6938qg/?q=&camera=
Can my camera even do this (minus the red h-alpha) or am I doing good with what I have? Thanks again!
Benjamin
dkamen avatar
Benjamin DeHaven:
Benjamin
That image is done with a ten inch f/4 telescope, you simply cannot capture the same stuff with a 500mm lens at f/5.6. Regardless of camera used.
EAF on Evolux 62ED
Hello AB, I installed a ZWO EAF on my Evolux 62ED but the focuser is jiggling inside the tube when the lock screws are removed. Does this happen on most scope or is mine just as bad a scope as I now think it is ? Won't this induce tilt and screw ...
Photoshop workflow help! — Hello! I'm a newbie, started in Oct 2023, and has been doing my best with Photoshop (it's free with my work and I can't afford PI yet). I learned a l
Jul 4, 2024
Hello! I’m a newbie, started in Oct 2023, and have been doing my best with Photoshop (it’s free with my work and I can’t afford PI yet). I learned a lot from Nico’s tutorials on his channel, Nebula Photos, but I’m wondering if there are any other res...
Dirty mirror or poor seeing or faulty processing ? — Dear fellow astrophotographers Along my journey to better images, where progress goes hand in hand with increased expectations and discoveries of n
Jul 19, 2024
