UV/IR Filter for OSC and Gerd CTU
Takahashi Epsilons 4 replies99 views
Shinpah avatar
Hi all,
I've been fighting with various collimation and tilt issues for the last year with my 130D and I wanted to know if anyone here has any opinion on two things
a) If a Gerd CTU would be a reliable tool for eliminating sensor/image train tilt and
b) If a UV/IR filter is actually necessary for a OSC camera (Risingcam 571) with the epsilon
The reason I'm asking is because I currently have a UV/IR filter in a ZWO filter drawer as part of my image train (which is mostly agena blue fireball M54 spacers and some fine adjustment spacers) and I wouldn't have the proper backfocus to fit in the filter drawer and the M68 CTU.
I've tried using copper tape attached to where the camera threads into the first spacer to try to remove the tilt but it isn't reliable or a fine adjustment for a small adjustments I need to make.
Thierry Boufflet avatar
Hello Shinpah,
I can only reply to second issue. The IR/UV filter is necessary on RisingCam IMX 571 color only if your order the model with simple protection glass. It is not usefull on Monon version because you will use other filters that blocks the IR/UV.
Cheers
Thierry
Thorsten Glebe avatar
Hi Shinpah,
I use the following tilt adapter for my Epsilon 160ED (backfocus 56,2mm) as it has an optical length of only 10mm:
https://www.intercon-spacetec.de/foto-und-ccd/zubehoer/adapterringe/andere-fotografische-adapter/6435-m54-neigeflansch-tiltadapter-.html
It works well in combination with an ZWO EFW filter wheel (optical length similar to ZWO filter drawer).
Kind regards,
Thorsten
Well Written Helpful Concise
Shinpah avatar
Thorsten Glebe:
Hi Shinpah,
Kind regards,
Thorsten
Do you have any photos of your image train you can share; are the screws accessible without dethreading any of the rest of the train.
My image train looks like this:
You need an Allen Key set with short heads, like this one:
https://www.amazon.de/-/en/Bondhus-Stubby-SBLX7M-16792-7-Piece/dp/B0006O4AHY/ref=sr_1_2?crid=29Z3F0CZ8VCQI&keywords=bondhus+inbus+stubby&qid=1661362984&sprefix=bondhus+allen+stubby%2Caps%2C70&sr=8-2
The small screws are easily accessible, the big screws can be accessed in some small angle with above Allen keys.
27% Tilt on my Celestron Imaging Train
Switching over to a longer focal length setup for galaxy season. Was using a WO GT81 refractor and an imaging train consisting of a WO refractor reducer/ corrector, filter wheel, tilt plate, spacers and a ZWO AS294MC Pro. I used ASTAP to check for ti...
Author discusses tilt issues in imaging train; directly relevant to collimation concerns.
Feb 16, 2024
Beta Testing ASG Electronic Assisted Tilt (EAT) Device
Hello folks. I've been largely absent from the forums for the last couple of months due to my work. Josh from ASG contacted me and asked if I would be interested in testing out a prototype of a motorized version of the Photon Cage. Of course, I&#...
Electronic tilt correction device directly addresses author's sensor/image train tilt problem.
Feb 3, 2024
