Eliaasp avatar
Hi!
I'm thinking of buying the RedCat 51 by Williom Optics. I have a nikon d5300 dslr which is a crop sensor camera. In william optics' page, thay say that the RedCat 51 is compatible with full frame and crop sensor cameras. What adapter do I need for my camera to be able to attach it to the redcat? Do I need something more than an adapter?
I'm very new to this and don't understand a damn about telescopes..? I've done astrophotography for 1,5 years now and I am only 17 years old… smile
Thank you in advance!
Daniel Tackley avatar
You just need an M48 to T Mount adapter for a Nikon camera.
Sean Mathews avatar
The Redcat is a great scope.  I have one and use it with a ZWO 1600.  With a DSLR you have even more versatility being able to shoot daytime terrestrial objects.
Dawn Lowry avatar
There have been reports that if you use a standard t ring. The 1 mm backfocus is affected. So it is recommended that you actually get the t ring from Williams optics.
What mount as you using?
Sean Mathews avatar
Dawn Lowry:
There have been reports of this, but I have seen otherwise.  I use a regular old 16.5mm adapter I use on my other OTA and it works perfect.  I have barely perceptible coma in mine.  You can view my Heart Nebula image and see for yourself.  I either won the optical lottery, or WO has made some changes since their first run.  My scope was made on 7/18.
Eliaasp avatar
Dawn Lowry:
There have been reports that if you use a standard t ring. The 1 mm backfocus is affected. So it is recommended that you actually get the t ring from Williams optics.What mount as you using?
I'm using a nikon d5300...
Dawn Lowry avatar
I meant the actual
mount the telescope and the camera would go on…  additionally the Nikon t ring is all you need for a 48mm connection. They make 42mm and 48mm. The cat is a 48
Dawn Lowry avatar
I meant the actual
zicklurky avatar
If your vendor offers an optical test of the telescope before they send it to you I'd recommended you opt for that. They seem a bit hit and miss. Most are fine, but some of them are not collimated correctly.
Well Written Concise
Adapters?
Hi! I'm new to deepsky astrophotography, so I don't know much about the equipment needed in this category. All I've done so far is astroscaping (wide-angle photographing the Milky Way) and once earlier taken an image of the Orion nebulae ...
Discusses adapters for astrophotography equipment, directly relevant to adapter question.
Aug 6, 2020
First timer in need of help.
Hey all. I'm fairly new to all this and, as I'm into my photography I've bought some adapters so I can attach my DSLR to my telescope to photograph the moon and our closer planets. Now that the skies have cleared up I managed to get out t...
Covers DSLR attachment to telescopes using adapters, directly addresses main concern.
Jun 22, 2020
