Going mono: advice on filter set selection
Frédéric AuchèreAndy WrayBrentWei-Hao WangRouz Astro
39 replies1.1k views
Frédéric Auchère avatar
Hi all,
I've been using OSC cameras only (EOS 6D & ASI 178 MC) since I've re-started astrophotography four years ago, first with a Samyang 135, and then with an ESPRIT 100 ED. I've definitely not yet exploited that relatively modest gear to its fullest, but I feel it's time to spend some money ;)
I'm thinking of finally buying a dedicated astro camera, namely an ASI 2600 MM. For the filter wheel, I'm looking at the ZWO EFW 7x36 mm V2. The only filter I own today is an Astronomik L2, with which I had no problems, so I'm simply thinking of going for an RGB set from that brand + eventually H-alpha 6 nm.
Now for the questions to the experts smile
- The ZWO FW is relatively cheap. Are there any known issues with it?
- What about the filters themselves? Are there significant differences between brands for the RGB filters? For H-alpha, Baader has a 3.5 nm "f/2 Ultra-Highspeed" version that sells for ~the same price as the 6 nm Astronomik. Is that any good?
Frédéric
TakFan avatar
Dear Frédéric,
I am using the 2600MM-PRO with ZWO FW 7x & new 36mm Baader Filter UNB (for slower focal lenght). The Ha results in Halos. Using on an TSA-120 with reducer, flattener and extender from Takahashi.
And I was told to go for Astronomik instead. Didn't listen to the advice, though .
The EFW works fine for me.
Dirk
Dear Frédéric,
Dirk
I suppose I should stay away from the Baader and stick to Astronomik then.
Thanks for the feedback!
F
Alfonso Caschili avatar
I have been using the 2600MM with the Zwo EFW 7x36v2 and the Astronomik LRGB + SHO 6nm filters for about a year and half now and am perfectly happy with the filters. The Efw is ok, had to tape it all over to prevent light leaks but besides that it has worked flawlessly.
Alfonso Caschili:
Light leaks? Ah, good to know, thanks for the tip!
F
Andy Wray avatar
The main thing on the ZWO filter wheel is to set it to unidirectional mode.  In that way it more accurately positions the filters and matches your flats.  It may take longer to change filters, but it is worth it.
Well Written Concise
Andy Wray:
One more good piece of advice How long does it take to move from one position to the next? Also, as I may not buy 7 filters at once, I suppose it would be better to load the empty positions with dummy masses to keep the mechanism balanced. Any recommendations for that?
F
Andy Wray:
F
Leonardo Landi avatar
Anyone uses Optolong filters? I have the complete LRGB+Ha OIII and SII and works great. I'm waiting for the 3nm 31mm filters
Mark Abbott avatar
I’m no expert but I recently purchased a mono camera (294mm) and went with Astronomik deep sky RGB and narrowband filters.  I’m very happy with them and they seem to be a good bang for the buck.
Thanks Mark & Leonardo! The Optolong 3nm seems interesting for its price. Any feedback on that one?
Andy Wray avatar
Frédéric Auchère:
No need to worry about that ... the mechanism is more than capable of coping.
Andy Wray avatar
Frédéric Auchère:
A couple of seconds.
Brent avatar
Bottom line up front: parfocal filters, it matters.
background: the glass thickness influences back focus, so if you have one brand of LRGB filters and another brand of narrowband, the required back focus may be different!  and that does not make for happy imaging.
I have gone astronomik all the way... now.
I wanted to save money on the LRGB filters and went with ZWO filters there, and astronomik for narrowband.
I wanted RGB stars for some of my narrowband images and quickly realized, how significantly different the back focus was.  I do image on fast systems ( f/4 newtonian, and f/2.2 hyperstar) where this effect may show up more.  shooting at f/7 the effects may not be as strong, not sure?
This can also influence focus on off axis guide (OAG) scopes and keeping them in focus as you change filters.
if you want a technical deep dive - I did a video on dichroic filters, figuring out where reflections come from, and how/when to think about bandwidth for narrowband.  because I do a good bit of fast optics I settled on the MaxFR filter set.
https://youtu.be/DW081qgoPUU
and
https://youtu.be/rtFX92dZE_w
Helpful Insightful
Brent avatar
I also talked with Gerd Neumann from Astronomik last week - he was recommending the 'deep-sky' RGB filters rather than the type 2C.
they have slightly different band pass than the 2C RGB filters.
Astronomik Deep-Sky RGB Color Filter
Andy Wray avatar
Brent:
I'm not sure I understand what you mean by the above?  An OAG would be placed before the filters in the imaging train and as such would not be affected by them
Wei-Hao Wang avatar
Andy Wray:
If your filters are not parfocal, you need to refocus after you change filter.  This will push your OAG out of focus.
Andy Wray avatar
Wei-Hao Wang:
Andy Wray:
I think I get the point now, but not sure it would have any appreciable affect on the OAG.  I have non-parfocal filters and it has absolutely no affect on my guiding.
kuechlew avatar
Andy, you're imaging with 800mm focal length while Wei-Hao Wang images at up to 3500mm focal length. Focus plane is quite a bit smaller and the OAG may loose the stars at very slight focus shifts.
Clear skies
Wolfgang
Insightful Respectful Concise
Clear skies
Wolfgang
Critical focus zone (cfz) is determined by focal ratio, not focal length (and does vary slightly by bandwidth). I don't know what scope Wei Hao is using but a 3000mm f10 scope is more forgiving with focus than a 500mm f5.
With my edge scope I was able to mix 1mm and 3mm filters. The oag camera was set to focus right in the middle.  So it was never perfectly focused but stayrd the same between the two filter thicknesses. I could not get away with this on my shorter refractor.
To the OP:
I use chroma and astrodon now, but if I was to buy filters again, I'd go with the astronomik deep sky rgb and the max fr for narrowband. Much more affordable and proven performers.
Helpful Insightful
Rouz Astro avatar
Frédéric Auchère:
Hi all,
Frédéric
*I recently have a detailed comparison of 3nm vs 5nm here:
 https://astrogeartod...astronomik-6nm/
Rouz
https://www.rouzastro.com/
Wei-Hao Wang avatar
I am also looking around for filters.  It's interesting to hear that Baade NB filters produce halos.  Can others confirm?
Rouz Astro avatar
Wei-Hao Wang:
*I have a 3.5nm from a 3 years ago, it did suffer from halos.
Rouz
Wei-Hao Wang avatar
Rouz Astro:
Wei-Hao Wang:
Rouz
Thanks!  It's very important to know this.
On the other hand, on Baade's website:
https://www.baader-planetarium.com/en/blog/new-cmos-optimized-baader-filters/
there seems to be some updates in their filter formula lately.  Has anyone tried their latest batch of NB filters?  Any improvements?
I am seriously consider Baade because it appears to be the only manufacture that offers all the filters I want with equal thickness.  My size and filter type requirement is kind of special, and Baade is the only one who has all.  However, if there are halo issues, I will reconsider this.
Rouz Astro avatar
Filters being parfocal isn't necessary.
Even if they are, you telescope is not "parfocal" unless you use a reflector only system like a pure RC or Newtonian (no correctors).
I mix 1mm, 1.1mm and 3mm all in the same filter wheel.
while that is extreme, mixing different 1mm or 3mm filter brands will not be a huge issue for the OAG.
In any case, its always best to calculate offsets between filters if you don't want to refocus (NINA does that).
I would never assume perfectly parfocal no matter what.
Rouz
https://rouzastro.com/
Hi from France
Hello all, I’m Fred, I live in France, I do astrophotography with my modest equipment, canon 6d modded and a star adventurer.
Canon 6D user discussing mono camera transition from your current setup.
Sep 9, 2020
Halos with DeepSky RGB filters
Hi there, I just bought a set of Astronomik Deep Sky RGB filters so I can use them with a new Poseidon M PRO (switching to MONO from my ASI294MC PRO after two years). I've noticed that with no filter or with my current Astronomik L2 filter, there...
Switching to mono camera; discusses RGB filters for dedicated astro camera.
Feb 12, 2024
ASI2600MM or ASI2600MM Duo
Hello, I'm a relative newbie to astrophotography (I've only been doing it for a year, and even less with a traditional set up) and have recently ordered a second mount so that I can take more images in a single night. With an additional mount...
Direct discussion of ASI2600MM camera selection and setup considerations.
Jul 14, 2024
LRGB filter reviews and recommendations
Hi gang, Filter technology has changed and improved greatly over just the last few years. As such, my 30-year-old set of 1.25" LRGB filters is well past its 'sell by' date, and I would like to update it. I use them with a QSI CCD camera ...
LRGB filter reviews relevant to filter wheel and filter selection planning.
Feb 8, 2024
ASI 2600MM Kit?
I am quickly getting into the deep end of the pool. I bought an SVX152t a few months ago - reduced images are fine, but with the flattener @1200mm realize I need to track via OAG, which has set me into thinking thru options. I read an article somewhe...
ASI2600MM kit discussion with similar equipment upgrade considerations.
May 10, 2024
