NINA and QHY CFW3 4pin cable don’t find !
3 replies169 views
Themis Karteris avatar
Hi folks
after 5 months without a problem the Nina dont show in the list the Cfw3 fw. I use Nina beta 2 qhy268m qhycfw3 native drivers updated for all and the 4pin cable. The mode in Cfw3 is in green mode.
what else I can check it?
kuechlew avatar
First check is obviously to replace the cable. From your posting it's not appearent if you did that.  Cables can stop working for a multitude of reasons. That's why I always have a replacement for any type of cable I'm using in my bag.
Good luck and clear skies
Wolfgang
Concise
Nadir Astro avatar
Why to use beta when there's a stable NINA 2.0 version ? Try to install it.
Then completely delete and install the latest stable drivers from QHY website.
Then check all cables (power, USB, 4pin) and try replacing them.
Last but not least - check if camera gets enough power (like 5-6 ampers 12V).
deanrowe avatar
Try setting the button to switch the CFW3 to USB and then back to the 4 pin connector. I've done that a couple of times when nothing could see the CFW3 and it worked each time.
Well written Concise
ASIAIR+ lost wifi after firmware update
Hello, not sure if my ASIAIR+ is bricked by went to test my equipment this afternoon to make sure everything was running smoothly after about 6 months of being in the closet. I booted up my ASIAIR and connected as usual. It showed there was a firmwar...
Device not appearing after firmware update; similar hardware communication issue.
Jun 30, 2024
