Looking for advice on roof automation
5 replies298 views
Hello everyone.  I built a small backyard observatory a few years ago.  It's been wonderful for me to be able to get out and image any time I want regardless of how tired or unmotivated I am.
It has a manual roof and I'm looking for ideas on how to motorize and automate it.
I am mechanically inclined, so rigging something up is not intimidating for me.  However I am pretty ignorant when it comes to software code, so I'd need something that is easy as far as the integration with my software capture is concerned.  Maybe something like this already exists?
I use voyager in case that matters and I also already have a cloud watcher setup for weather monitoring.
Thanks all,
Luca Marinelli avatar
Hi Chris,
I have a backyard observatory with full roof automation. There are homegrown solutions based on Arduino controllers but given the consequences of failure of the control software, I chose to go with a commercial solution. I have installed an Aleko gate motor with a fiberglass gear track lag bolted into the roof and use the SkyAlert/SkyRoof system by Interactive Astronomy (also Arduino based) for weather station and roof controller (https://interactiveastronomy.com/skyroof.html). Both SkyAlert and SkyRoof come with ASCOM drivers that can be immediately integrated as safety monitors and weather condition monitors in any imaging application. I am also pretty sure you can continue using your Cloudwatcher device as long as it outputs a Boltwood style weather file. SkyRoof reads the Boltwood file and has its internal logic to decide when to close the roof based on a combination of clouds, precipitation, humidity, temperature, wind, and sensor malfunction.
Luca
Helpful Respectful
Bruce Donzanti avatar
Chris
Here is the automated system I use on my ROR……. http://piertechinc.com/roll-off-roof-observatories/automation-system/
Bruce
Luca Marinelli:
Hi Chris,
Luca
Luca,
I think this might be just the thing I'm looking for.  Looks like a turn key solution, just need to install all of the gear.
Thanks for the suggestion!!!
Jerry Yesavage avatar
I have the industrial solution from Pier-Tech.  It is bomb-proof but $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
When to shoot; and when not to!?
Greetings, I am sure I am not the only one out there waiting for the clouds to pass and stars to come out. That said, it has me wondering: If it's not fully overcast but just some scatted clouds, do you still shoot and the cull through to get rid...
Discusses observatory setup for flexible imaging during variable conditions.
Sep 11, 2020
