A somewhat philosophical question raised here.
I have a large Newtonian (VX12) that works very well indeed save for the fact that it is currently producing slightly (r ~ 0.87) egg shaped stars- all consistent across the field and orientated the same. As you all know this can arise due to a mismatch in RA v DEC guiding or - perhaps more likely some tilt introduced during alignment of the focuser. Whatever - these minor problems can take forever to solve and getting everything near to perfection in a large Newt takes time because there are many parts that interact and inter-dependencies.
I don't want to spend time that could be imaging dotting the last i's and crossing the last t's in a setup that is already pretty good.
So at the moment I just live with it – and then fix things in post processing by measuring the PSF across the field and applying (just enough) deconvolution to the image. The results then seem fine - I would guess indistinguishable from if I had started from r = 0.95 or better in the first place?
So it sort of raises the general question of how far is it worth going down the road of seeking perfection in optics, alignment and telescopes etc. - and how many errors and problems in these (if consistent enough) can be adequately compensated for anyway during image processing?
Interested to know the thoughts of others on this.. it almost seems like cheating
best wishes
Tim
best wishes
Tim
