problems after home work with my telescope
9 replies506 views
marianobritogomez avatar
Hello everyone.
These last few days I have been trying to upgrade my sky watcher 150/750. I have flocked the inside of the tube, painted the sides of the primary and secondary mirrors, put an aperture ring on the primary mirror and trimmed the focuser tube 2 cm so it doesn't protrude. The problem I am having is that the stars now appear weird, as in the image I am showing you. I have collimated both mirrors with a laser collimator and they seem to be fine, however this problem has not been solved.
I hope that if any of you have had this problem you can tell me how to fix it.
Thank you very much.
Well Written Respectful Concise Engaging
Björn Arnold avatar
Hello everyone.
Looks to me as if you had pinched the primary mirror. Did you work on the mirror clips holding the primary mirror?
Björn
Yes I did Björn, to place this accessory in the primary mirror:
aperture ring
Björn Arnold avatar
aperture ring
Then you should check that. The clips holding the primary shouldn't be too tight as this leads to deformation of the mirror.
Great. Thanks Björn Arnold for the quick help I'm going to fix this right now.
robonrome avatar
Make sure to let us know if this works too. Makes sense.
Hello everyone. The problem has been solved. Here is a picture taken last night.  It is always a pleasure to learn with all of you. Thanks for your help, The problem now is that an oval reflection has appeared around the star, also if you notice, the star is not even centered in the oval. If possible I would appreciate some advice.
Thank you very much
Hi. I finally managed to solve the problem by adjusting the spider properly and releasing the secondary mirror screws a bit, which were quite tight. The image is now sharp and without that strange halo.
Thank you.
Andy Wray avatar
@marianobritogomez   When you say you adjusted the spider, what exactly did you do?
same distance on each leg of the spider @Andy Wray
Newt Astigmatism: tilt or secondary mirror?
Hello, I'm struggling to get good star shapes across images from my ONTC 10" F4, specifically around the corners. I tried everything and can't seem to locate/confirm the source of my problems. Some information about the setup: General Se...
Addresses astigmatism and secondary mirror issues affecting star appearance.
May 24, 2024
Backfocus C8 + Barlow : Help.
Hello everyone, i have a question about the C8 back focus. Indeed, for planetary acquisition, I use a Crayford 13cm long, a X-CELL X2 Barlow, an extension tube 50mm and my 1100D but the results are not very good, as you can see… https://www.ast...
Telescope upgrade and modification experience applicable to equipment optimization.
Oct 11, 2020
