Tips for fighting light pollution (needed)
11 replies580 views
matt113d avatar
Hi everyone,
Due to a series of purchases recently I have gone from unguided alt-az with max exposure times of around 10s at 600 mm focal length to guided eq tracking beautifully giving me 10 minute exposures at every focal length I have access to.
​​​​​However. Light pollution is causing me big problems. I live in bortle 7/8 Sheffield in the UK and I'm getting awful gradients and struggling to capture details. I'm using a full colour hypercam 294 and have no filters. Do I want super exposure times, swamp noise with hinders or thousands of short frames? Or both? Any advise would be really great!
I don't have the option to spend anymore right now without risking divorce so I was hoping for some tips and tricks from the fantastic community that have helped me out already so much!
Matt
Jared Holloway avatar
I live and shoot from Bortle 8 in the USA. I do use filters - started with a cheaper general light pollution filter and now use L-Pro, L-eNhance, etc. Without filters, my histogram would tell me to shoot 30s or less, though I would push it to 60s (480mm / 80mm f6), only with filters could I conceivably go longer with my exposure times. You'll still habe gradients to deal with - processing software can help (Siril is free, for PS you can get something like GradientXterminator)
It also helps to pick targets that are away from any harsh ambient light. A dew shield can be helpful as well, though not an overall solution.
Andy Wray avatar
I live in a Bortle 5 area and my exposures are typically 30 secs for Luminance (i.e. no filters), 90 seconds for Red, Green or Blue filters and between 180 secs and 300 secs for Narrowband.  If anything your exposures should be less than mine given your location.
So, with 10 minutes exposure you are maybe spending 9 minutes of that capturing light pollution.
Filters will help a lot.
Without any filters is a tough call but it can be done and I've done in my Bortle 7 sky in Lincoln. The basic criterion is to shoot high to avoid the worst of the light pollution. And shoot bright targets for your pixel scale and aperture. Flats are critical to get good results as well as good post-processing techniques. Total integration times vary with subject but I've found that 180s works with most of them, regardless of light pollution.
Brent avatar
The technical answer is covered here https://youtu.be/3RH93UvP358
you need to balance sky (shot) noise and read noise with exposure duration and gain.  Not fun, but it does come down to the statistics of the noise.
I suggest, design some controlled experiments trying a few ideas and compare the results of stacking ~15 images per whatever conditions you choose.  Prove to yourself what works
deleted avatar
Get Astroflat Pro, works wonders!  I've tried GradientXRemover but it didn't work as well as Astroflat Pro for me.
Dan Kearl avatar
It seems like a few hundred dollars for a filter after what you have spent is nothing compared to getting bad results with what you have.
I live in Bortle 8, I would not spend the time and effort without a filter.
You have a nice mount and camera, the filter is a very small investment to get good images compared to the money you already spent.
Daniel Arenas avatar
Hi @matt113d,
If you can't spend money in narrowband filters for color cameras such us L-Extreme o L-enhance, maybe there are few things you can do.
1- The higher you are, the better. That means that if you are in a backyard with the street illumination close to you that could be a big issue that can be not minimized either solved but if you are in a terrace the bell that draw the light pollution will affect you less.
2- Move to do astrophotography far from cities if you can in a less polluted sky.
3- Go to a mono camera, but that means more budget and a new learning curve and the problem is the same, the budget.
Kind regards.
Torben van Hees avatar
You will probably still use short exposure times, as that's enough to swamp read noise with your camera in your light polluted skies. Camera noise really is not your problem. Shot noise and gradients are. To fight the shot noise of light pollution, you need to shoot a lot of subs. For the brightest targets shoot 10h, for most galaxies, 20h, for nebulae 40h: Most emission nebulae are as faint as reflection nebulae without a narrowband filter. At Bortle 5, I need about half these times, but more is always better. Then cull the subs, mercilessly, especially those with high clouds. They will introduce complex gradients and artefacts because they throw off normalization and pixel rejection with subs swamped with shot noise.
As you won't want to calibrate 15s subs of a 40h project, you need to be able to shoot longer subs without burning out more stars: Use the lowest gain that your camera can do. I have a QHY268M and in Bortle 5 I can do 120s Lum subs without overexposing on a F/3.3 Epsilon due to the "extended well depth" mode. For the hypercam, set "LGC" mode and gain to 0. You should be able to get at least 60s subs that way, maybe 90s or even 120s.
Optimize your telescope: Use a long dew shield. Get rid of any reflections, blacken the tube, possible mirror surfaces and interior surfaces of any adapters. Use something like Black 2.0/3.0, but educate yourself on its use before, it's not straightforward. Alternatively, velour also works, but not as well. If it's a mirrored telescope, get information on baffling and see if any can be added/optimised without vignetting your chip. Any light not from your target that lands on the chip is a problem - and there is a lot of that around you.
Optimize your surroundings: Try to get to a shielded place away from stray lighting. Turn off your own outside lights (and ask neighbours to do the same, if possible). Get your community to employ measurements against light pollution (many of those actually save money in a rather short timeframe).
You could also do mobile imaging: If you can get to Bortle 3, you will only need 1/4th the exposure time and fight far fewer gradients. Now that I write that, I think I should get my … up and do more mobile imaging myself. It's just so convenient to have the scope sitting in the backyard…
Also, don't despair, and have realistic expectations: You're trying to make images of targets that your pixels only detect one photon of every few seconds. And that with a sky that is bright enough to read under.
Dan Kearl avatar
If you think you are risking divorce by spending a few hundred dollars for a filter, having to put in 40 hours to get a decent image of a single target without one will probably cause a lot more problems in your relationship.....
You also can shoot in moonlight with a filter so will get a lot more nights available to make images.
I took this last night with Full Moon in Portland Oregon Bortle 8.
3 hours. quick edit.
Radian filter which is expensive but you can get similar results with much cheaper filters.
The best money you will spend.
Steve Spring avatar
Hi Andy,
Looks like you've been given some good tips without having to spend any money which is what you asked for.
Everyone's budget is personal and so I fully understand why you can't spend anymore right now. Just carry on the way you are, every nights session is an opportunity to focus on what you have, make the next incremental improvement and bullet proof all those little things that want to go wrong in the dark.
When you can afford it, then get yourself a couple of filters. It doesn't have to be really expensive as you may think. There is A 1.25 IDAS LP2 filter on Astrobuysell.com (UK) for £55 at the moment for example.
Whilst your waiting for the money, use those endless cloudy night here the UK researching what you need and looking for bargains
Check out https://astronomy.tools/calculators/ccd_filter_size tocalculate what size filter you will need and research how you will fit it in your imaging train.
I also shoot with an OSC (ASI533MC) and 1.25 filters close to the sensor saved me alot of money.
If it helps, from my experience, I would get one light pollution filter for reflection nebula and galaxies which I would only shoot if the moon was not up.
One narrow band filter for emission nebula. This will blow you away when first see the results, it's the single biggest step change in my progression. As said before here, you can shoot with this in a full moon, but you will probably get halo's around bright stars and not suitable for gathering OIII. It won't bother you to start with, but you will soon want better.
I also use an IR/UV block to reduce star bloat but that's because I'm in bortle4 (sorry to gloat and don't often use my light pollution filter.
Hope I'm not teaching you to suck eggs, but wanted to share some of my findings in case it helps. If you're guiding 10mins then you've got yourself in a great position to get some images you will be really happy with
Steve
dkamen avatar
I find that under severe LP it is better to do shorter and many more exposures than longer and fewer.
Galaxy Season is here!
I've never been a big galaxy imager. Galaxy season only spelled the end of nebula season for me. Andromeda, M81 and M82 and the Leo Triplet is about it. However, this year, my interest in imaging galaxies has come alive. I decided to break out my...
Galaxy Season addresses light pollution challenges and target selection for imaging.
Mar 19, 2024
City astrophotography
I apologize if this has been covered but I was looking for some opinions. I live around the Chicago area so I have a lot of light pollution (class 8-9). I recently bought a Celestron 6se and I am enjoying it, but I have already gotten the bug to star...
Light pollution mitigation strategies essential for author's Chicago class 8-9 location.
Mar 31, 2021
First attempt on drizzling - when and how ?
Hi all, After processing almost 40 hours of data from a Bortle 4 sky of M106, I expected way more details to appear in the galaxy. This image has been processed using BlurX, LHE, MLT and unsharp mask on the L layer before combining to HaRGB but zoomi...
Drizzling techniques help extract detail from data in light-polluted skies.
Apr 22, 2024
