Best way to identify galaxies
12 replies726 views
Andy Wray avatar
Just wondered what the best way is to identify background galaxies in your images.  e.g. the one pointed to by the arrow below
M51 with only 3 hours of integration
Tom Boyd avatar
If you use Pixinsight you can plate some the image and annotate it…
matthew.maclean avatar
Depending on your membership level, Astrobin can add a lot of annotation too.
In the image edit menu, if you have Advanced Plate-solving Settings, you can turn on Show PGC objects and restart the advanced plate solve. It will surely be in the PGC database.
From a very quick glance in my Sky Safari app, my guess is it might be PGC91291. There’s also one just a little directly back toward the Whirlpool too that might be PGC3482152.
CCDMike avatar
You can use ASTAP as stand-alone-sollution, too.
Also very helpful with asteroids.😎
Cheers
Mike
Wim van Berlo avatar
In PixInsight you can load the SDSS R7 catalogue. This contains a lot of faint galaxies. I do some of my identification work manually inAladin and Simbad
https://aladin.u-strasbg.fr/AladinLite/
falke2000 avatar
You can also use Aladin Desktop to annotate platesolved images:
https://aladin.cds.unistra.fr/java/nph-aladin.pl?frame=downloading
To do the platesolving, you can upload your image to Astrometry.net (https://nova.astrometry.net/) and download the new-image.fits file from the output (But you can use any other platesolving program you like for this). Then you can import the image into Aladin and click on "Simbad" to show the annotations.
If you are into Python you can even write your own program which exports a list of background galaxies, stars, ... filtered by custom criteria (type, redshift, magnitude) as shown below:
Seymore Stars avatar
Download and install Aladin desktop version (easy simple)  - https://aladin.u-strasbg.fr/java/nph-aladin.pl?frame=downloading
Run Aladin and type the know local galaxy (M51) into Aladin's "Command" box. Zoom in and star hop to the object in question and left click on it (cross hairs appear).
Continue to hover mouse until pop-up information appears.
Here's the cut&paste from the Aladin screen ...
Note: I had to laugh at it's description LINER.
If I star hopped correctly your galaxy in question appears at the bottom of the page below and is named 2MFGC 10831
http://aladin.unistra.fr/simbad-thumbnails/thumbnails2757.html
Bob Lockwood avatar
The Sky 6, the version I'm running shows it as PGC  91291
Björn Arnold avatar
You can also use the NASA extragalactic database:
https://ned.ipac.caltech.edu/
It‘s manual work but a very extensive database.
Björn
Andy Wray avatar
Björn Arnold:
Björn
Thank you, that is really useful and, as you say, a very extensive database.
Marc V avatar
SIRIL does it for most DSO and you can also add annotation to your picture…
UlfG avatar
Upload your image to https://nova.astrometry.net.
UlfG avatar
@Andy Wray I had a look at this image in your Astrobin collection, and with plate solving overlay turned on, the galaxy is identified.
RC Blur Exterminator. Poor star shape/ eccentricity of input images has little deleterious impact on the quality of the final output?
Just interested to know if folks are on the same page when using this tool? I have been working through hundreds of recent and past image files to better understand which parameters of input images are the most critical to getting the best possible f...
Discusses image quality assessment tools relevant to identifying features in images.
May 22, 2024
What is real and what is not? How to know what to include...
Hi, as I always stated, image processing isn't my thing. But while forcing myself to progress in this field, I ran into some issues no tutorial seems to care about. Let's explain the problem. For my latest images I took the time to collect at...
Addresses distinguishing real astronomical objects from artifacts in processed images.
Jul 11, 2024
