Help with background extraction
1 reply261 views
Andy Wray avatar
I'm struggling with getting my backgrounds even and neutral and had a few questions:
1)  I tend to use DynamicBackgroundExtraction in PixInsight using a Tolerance of 2.0 and a smoothing factor of 0.5 ... what starting parameters do you use before Sample Generation?
2)  Do you use DBE on individual channels or on the RGB?
3)  Do you use LocalNormalisation and, if so, under what circumstances?
An example is the below image of M51 where I still have background issues:
Original is here:
M51 with only 3 hours of integration
Best thing would be to give the raw RGB out and see how we do it. As for the 2 & 3: DBE operates on each single channel differently (different weights) so it doesn't actually matter (nor should it) and LN should be used always to as long as there is half-decent frame without heavy gradients and no satellite traces.
Ring Artifact after Background Extraction in Pixinsight
Dear community I recently got my new EQ6-R mount that finally allows me to take some nice image with my 10" Newton. So far everything works great, but I noticed a specific issue with my current setup. As you can see in the picture below, I get a...
Directly addresses background extraction issues and DBE/ABE processes.
Oct 8, 2020
Hello from Northwest Indiana
Hi folks, I'm fairly new to astrophotography and even newer to AstroBin. I've had an interest in astronomy since I was a kid gawping at the amazing Hubble images in whatever astronomy books I could find, had a couple of cheap telescopes over ...
Relevant for learning post-processing fundamentals like background extraction.
Nov 10, 2020
