I'm struggling with getting my flats to work with my lights and was looking for ideas. I'm using an LED flat panel and a white T-shirt cover on my OTA and when I look at the flats they look as I expect. Unfortunately when I integrate my images the flats don't sort out my lights. Please see below my master light and the corresponding master flat (all boosted auto stretch to exaggerate the issue). Any ideas would be appreciated?
FWIW: I used pixelmath to subtract 0.11 from each of the pixels in my flat and re-integrated and ended up with this for my master red light. I'm thinking because my flat panel is so bright, I am probably imaging the flats in the non-linear area of my sensor. I've ordered some A3 copier paper to dull down my panel.:
and in case it helps, here is an original sub on the left and the calibrated image on the right. It seems to be under-corrected:
