Help with my messy diffraction spikes
16 replies1.5k views
Andy Wray avatar
Below is a quick 1.5 hrs RGB capture of M51 that I took with my Newtonian.  The help I'm looking for is what you think is causing the messy one-sided diffraction spikes on my stars (see enlargement on large star later).  It really messes up large stars, but also impacts the shape of small stars.
Here's a 1:1 view of the large star:
and here's the original file:
M51 with only 90 minutes of integration
Well written Engaging
drblevy13 avatar
Is there something else protruding into your light path?  I have heard that an OAG stalk placed too far downwards can cause odd star shapes and diffraction spikes.  While I don't have experience with a Newtonian, perhaps check light path and collimation.  I also ended up with very peculiar diffraction spike pattern once when my velcro dew shield was deformed and was shaped more like an oval than a circle at its end.  Lastly, was there a meridian flip in the middle of your data?  While it doesn't look like that's the cause, I have had post-meridian flip diffraction spikes not line up with pre-meridian spikes creating a "double-vision" sort of look in the final stack.
Mainly though I just wanted to comment because it's a beautiful picture you have there!  Seriously impressive for such a short integration time.
Clear skies,
Ben
Looks like a tilted secondary. Fresnel rings image would help diagnosis of the ailment.
UlfG avatar
A known cause for 'extra' diffraction spikes in Newtonian images are the primary mirror holders that protrudes into the light path a little. A known cure for this is to add a so called aperture ring on top of them, which covers them. I have used one of these in my 6" Newtonian and it has helped. However, when these holders are the cause one would expect the spike pattern to be more regular with respect to the holders, and yours is not. But maybe you should have a look at them, even though something else protruding into the light path seems like a more likely cause in your case. Possibly, it could be that your holders are not protruding equal amounts over the mirror.
Ulf.
Wim van Berlo avatar
Something is in your light path, and it can very well be the focuser draw tube. My guess is that your spider vanes are parallell and perpendicular to your focuser tube, and not at 45 degrees. People have been known to solve this issue with a hack saw (on cheaper focusers), or invest in a focuser with a shorter travel length.
cs,
Wim
Andy Wray avatar
Thanks Andrea.  Just for clarity, what do you mean by a fresnel rings image?  Are you talking about an unfocussed image of a star or is there some other "fresnel rings" technique?
Jacob Heppell avatar
Clear skies,
Ben
if your diffraction spikes don't line up after a meridian flip, you have cone error. Gets worse the closer you are to the celestial pole.
If your secondary mirror is too small, you'll likely see this sort of diffraction. I used to see this sort of diffraction when I imaged through my goto dob, which has a small secondary. In general, any rough edge in the light path will contribute to diffraction. I highly recommend an aperture ring to eliminate diffraction from the mirror clips plus it also masks the extreme edge of the mirror and provides a smooth outer edge.
Well written Helpful Insightful
Andy Wray:
Yes, that is a way out of focus star.
Elmiko avatar
As Jacob said,the primary mirror clips are causing it… I made an aperture mask to cover the clips…
Dave Bloomsness avatar
I had the same problem and it turned out to be a turned edge on my mirror.
Dave
Elmiko:
As Jacob said,the primary mirror clips are causing it... I made an aperture mask to cover the clips...
I can see some "dark comet tails" that are associated with diffraction from mirror clips. Looks to be more too it though with all those outward radiating beams from the star. If Dave (above comment) is right about the turned edge, then the solution to both mirror clips and a turned edge is an aperture ring.
Dave B avatar
Your issue is being caused by 1/ focus tube sticking into OTA , if you fit a m48 adapter this should draw the drawtube out a bit more and if required trim tube  do not cut more than 15mm off tube assuming your using a skywatcher 200p .
2/ fit an apeture mask Deepskydad makes a nice mask that covers the edge of primary too .
Tim Hawkes avatar
I can't tell from your image but could it be a problem for the star you highlight but not right across the field?
Embarrassing to relate but I did one time report that I had a strange diffraction spike problem with my Newtonian - that just turmed out to be because the earth had turned and everything was lower in the sky than I had figured and now there were tree twigs and a TV ariel in line with part of my image
Tim
GTom avatar
Have you got it right by masking or removing the mirror clips in the meantime?
Aris Pope avatar
It's definitely from your mirror clips. You need an aperture mask. I ordered mine from here:
https://www.astrogoods.com/masks.imaging.shtml
It fixed my stars. I have it on both my 6" and 10" Newtonians
Backyard Universe avatar
Check this out
www.backyard-universe.de
the secondary mirror spiders will significantly improve the spikes as well as the collimating stability and the CNC machined primary mirror masks will remove such weird reflection/ diffraction patterns around stars.
original Skywatcher 200PDS
Skywatcher 200PDS upgraded with Backyard Universe Secondary Spider and Primary Mirror Mask
Takahashi E-130D Double Diffraction Spikes - trying to identify the cause
Hi there, So, I received my Takahashi e-130d several weeks ago. As is custom to receiving new equipment, I had cloudy skies for a couple of weeks. I ended up taking it out for first light on 04/06/24 (april 6) and noticed the diffraction spikes on th...
Discusses diffraction spikes in Newtonian telescopes; directly relevant to author's problem.
Apr 13, 2024
Hotech Advanced CT Laser Collimator - What is causing this?
Greetings, I purchased the Hotech CT Collimator and have had a difficult time getting good results with it. I have watched the instruction videos multiple times over and I think I understand the concept well, but my collimation still suffers. My use ...
Addresses collimation issues affecting star quality; relevant to diagnosing spike problems.
May 2, 2024
