How do I connect AISAir to 10 Micron GM1000 HPS?
2 replies271 views
Ulf Jonsson avatar
I have a 10 Micron GM1000 HPS with either a Orion Optics ODK-10 or a Takahashi FSQ-106. So far I have used only the hand control to find objects to photograph. The 10 Micron GM1000 HPS is pier- mounted in my backyard observatory about 20 m from my house.
I use ASIAIR for controlling my other mount, a Skywatcher AzEq-5. There I can connect ASIAir direct to the mount instead of the hand control and it works fine. Can anyone tell me how to connect ASIAir to 10 Micron GM1000 HPS?
/Ulf
I suppose that the Ethernet or the Serial port would do (the serial port would need a RS-232 to USB adapter). There are INDI drivers to download, I gather.
vercastro avatar
I don't believe by default it supports 10Micron. Even if there's an INDI driver for it the ASI Air is locked down so I doubt you could install it custom.
I would highly recommend purchasing a mini PC with Windows 10/11 and running NINA instead. It has full native support for 10Micron mounts.
Running a proper PC also allows you to run 10Micron software to build and accurate sky model. Very important to take full advantage of the mounts significant capabilities.
Turning Star Adventurer 2i into a Go-To?
Dear AstroBinners, I managed to connect my SA2i to NINA! Super happy about it! So now I need a controllable Dec to turn it into a proper Go-To Here is my question; what is the easiest way to motorize the Dec? Are there any custom Dec brackets that ha...
Connecting control software to mounts; similar ASIAIR integration question.
May 30, 2024
Hand Controller Time out
Hello all, recently I purchased an ASIAIR and have been trying to use it in conjunction with my IOptron GEM28 mount. However, after focusing and polar aligning, when I go to slew my mount to an object the hand controller will shut down for half a sec...
ASIAIR hand controller timeout issue with mount connection directly relevant.
Dec 30, 2023
