Narrowband filter with a Newton F/4 ??
9 replies329 views
Max Gillet avatar
Hello,
I'd like to buy Ha and OIII narrowband filters because I live near a big town. The problem is that I have a skywatcher 200/800 F/4, and you know that big apertures and narrowbands are not friends… So my question is, if I have a F/4 telescope, will it works with a 6nm filter or I should use a 12nm ?
Thanks
Andrea Alessandrelli avatar
Max Gillet:
First time I hear this! Baader, Astronomik, Optolong make good NB filters. My suggestion is to search for your telescope in the AB search tool and pick up the narrowband images that you see.  I noticed that you use a Canon 700d as camera, do you have also a monochrome camera or do you plan to buy one?
Andreas Zeinert avatar
Hi Max,
F/4 is not very open, you could even use 3 nm but these filters are expensive and the gain is low. For optics with F/2.8 one needs to be more careful. Good NB filters around 5-6 nm are by far the best option for you. If you are in an urban area, I highly recommand not to buy 12 nm, you will get too much light pollution and as a consequence much lower contrast in your pictures.
Clear skies,
Andreas
Max Gillet avatar
Andrea Alessandrelli:
No it's for my Canon, I know it's not the best to use with narrowband filters but the monochrome camera will come later
Max Gillet avatar
Andreas Zeinert:
Hi Max,F/4 is not very open, you could even use 3 nm but these filters are expensive and the gain is low. For optics with F/2.8 one needs to be more careful. Good NB filters around 5-6 nm are by far the best option for you. If you are in an urban area, I highly recommand not to buy 12 nm, you will get too much light pollution and as a consequence much lower contrast in your pictures.
Clear skies,
Andreas
Ok that's perfect, I will buy a 6nm Ha and OIII filters. Thanks for the answer !
Siegfried avatar
Last full moon I use  a Castell UHC Filter:  It let pass O-III and H-Alpha/S-II.
This was the result on my Lacerta modified 200/800 Newton (Newton ohne Namen). The mirror is the same from SkyWatcher.
https://astrob.in/403007/0/
Due a  filtermismatch at full moon before … I used only a CLS + IDAS-D2 Filter at the same object:
https://astrob.in/397385/0/
The Sky background was heavy green :-) But this could be corrected while processing….
But narrowband on Bayer Matrix is hard…..
Siegfried
John avatar
i would suggest the baader 4.5 nm filters..they are great ,dont have halos etc.
cheaper then Astrodon.
https://www.baader-planetarium.com/en/filters/deep-sky.html
Luca Marinelli avatar
As others have said, no problem with narrowband filters on a fast Newtonian telescope. I use 3nm and 5nm Astrodons all the way down to f/3.6 on a reduced FSQ106 with no ill effects.
Well written Concise
Andy 01 avatar
I also use a 250mm f4 Newt with 3nm Astrodon Ha, O3, S2 & N2 filters with no problems  smile
Chris Sullivan avatar
When I was talking to the guys at Chroma, they said that their 3 nm filters were good down to f/3.1. Below that, the angle of incidence becomes too steep and the center wavelength shifts. Anyway, I've been using 7 nm ZWO filters since January 2017 and recently got a 6.5 nm Ha from Optolong and a 3 nm OIII from Chroma. I've used all on my f/3.9 Newt with great results.
Well written Helpful Insightful Concise
AstroDon filter issue--suggestions please
Hello I am wondering if anyone has a suggestion that might help me My imaging set up is an RC reflector with an FLI proline 16803 camera and 50mm Astrodon filters (LRGB + 5nm narrow band) I have had a string of issues…everything from my mount h...
Addresses filter selection and compatibility with imaging equipment setup.
Mar 1, 2020
filter opinions wanted
Hello everyone, I have a full set of 36mm Antlia filters. The narrowband are 3.0nm for the Ha and 3.5nm for the Sii and Oiii. I also have a full set of 31mm Astronomic with the 6nm narrowband set. I'll be using either set on a Redcat 51 with the ...
Discusses narrowband filters (Ha, OIII) and their specifications/usage.
Apr 9, 2021
Narrowband on an ED80 in light polluted skies
Greetings, I live in the very light polluted county of New Haven, Connecticut, just outside the city. My current imaging setup uses a Skywatcher ED80 Apo, 0.85x reducer/corrector, and an Orion Mono G4 CCD. I use an Orion Skyglow filter along with LRG...
Narrowband filters help combat light pollution; relevant to author's skyglow challenges.
Oct 31, 2018
