Hello fellow RASA8 users,
I have a problem with guiding my RASA8 and would like to kindly ask for your support as I am not able to solve my problem by myself.
The problem that I have is that I get elongated stars with 5 minutes subs. At 2 minutes subs - I think that everything is ok.
I am using an iOptron CEM 70 with William Optics UniGuide 50mm Scope and an Asi120MM mini.
The UniGuide scope is mounted on top of the RASA 8 on a second dovetail rail which I installed. The guidescope is mounted through an ADM clamp which holds it firmly in place. The ASI120mm is firmly locked in place with the rotolock of the scope. No cables are freely hanging from the cameras and equipment. With all of the above I tried to lock my equipment as firmly as possible in order to eliminate any differential flexure.
Actually I made the upper dovetail / ADM clamp upgrade yesterday hoping to solve the problem with elongated stars. Unfortunately it didn't help
I checked my frames from yesterday. Everything is ok with stars till the moment when the imaged object rises above 75 degrees (comes close to the meridian). Then I get elongated stars on 5 minutes subs. Things improve when the object descends below 75 degrees on the other side of the meridian.
I read that the best solution for dealing with this problem on an SCT is to use off-axis guiding. However this is no good with the RASA.
Considering the above I want to ask you to share your experience:
- whether you have the same problem;
- whether you have found a solution to it and if "yes" then what is the solution
The solution that I am thinking right now is to switch to 2 minute subs when I approach the 75 degrees mark and then switch back to 5 minutes subs after that.
Ah yes - I am using 5 minute subs in order to image some quite dim objects like the SH2-91 veil nebula.
Thank you for your support in advance!
Ivan
Ivan
