[RCC] M16 Eagle Nebula
2 replies200 views
spacekitteh avatar
https://www.astrobin.com/dfftnw/B/
I would like some general constructive critique (I know about bottom left corner; it's my first time using a rotator), and hopefully some advice on:
- How to correct for background gradients when the object fills the entire image? I'm pretty sure that's what has caused the purpley gradient.
- How to boost saturation without giving stars rainbow halos?
- How to get more detail in the dark regions?
- How to get rid of the stars as much as possible? Note that I use Linux and don't have an NVidia GPU.
David Nozadze avatar
Hello Spacekitteh!
This is a very nice footage on M16. If you are using PixInsight, please do try applying Dynamic Background Extraction, even though the object occupies biggest part of the image. You still may put few reference points on the background areas and then play with the settings. You can also try an Automatic Background Extraction and compare the results.
If you want to boost the deatils without affecting the stars, try removing the stars with the Starnet, process the starless image and reintegrate the stars back.
I think the only way to to boost details in the dark resgions is to get as much luminance data as possible.
David
Sean van Drogen avatar
Hi Spacekitteh!,
Had a look at your processing order and would make the following suggestion for your RGB at least
The following steps
1) Channel Combination RGB
2) DBE or ABE
3) PCC or Standard Color Calibration
4) Noise Reduction
5) Stretch
6) LRGB Combo
and then do whatever you normally do
Sean
GPU: CUDA yes but memory matters?
Hi, I'm trying to configure a good desktop computer for PixInsight and video edition (family hollidays and muy youtube channel). I will not use it for gaming. For Pixinsight I know that I need an NVIDIA that suports CUDA for a GPU acceleration in...
No - about computer hardware for PixInsight, not image processing techniques.
Dec 9, 2023
[RCC] M81 Bodes and Heart IC 1805
I hope I'm not being greedy, or more likely a glutton for punishment, by asking for 2 critiques, but they're very different subjects and processes IMHO. Bodes: https://www.astrobin.com/fx2397/ Heart: https://www.astrobin.com/8d64mk/ As a fun ...
Yes - requests constructive critique on astrophotography images like source post.
Mar 8, 2024
[RCC] Heart Nebula
https://astrob.in/i93k2x/0/ This is my first attempt in deep space astrophotography. I could not make my guider work - it was causing star trails. Unguided shots seem to work OK - so just went with that. First time using this gear - so had lots to le...
Author seeking critique on first attempt; this post requests constructive critique on first image.
Jan 31, 2021
[RCC]Celestial Incident Divergence Theory
I have never liked diffraction spikes, they indicate artifacts across the entire field of view, both seen and unseen. This was my attempt to solve the issue: Design 201910056 | IP Australia | Australian Design Search I designed this for my grandson, ...
Yes - addresses removing diffraction spikes/stars from astrophotography images.
Dec 6, 2023
[RCC] M42 Orion Nebula
Hi, I'm looking for constructive criticism of my latest capture of the Orion Nebula I'm fairly new to astro photography and like most people in England, am really struggling to get any time outside nowadays as it's rarely clear here in No...
Yes - requests constructive criticism on astrophotography capture and processing.
Mar 11, 2024
