Preprocessing Question!!
6 replies245 views
gturgeon avatar
Two quick questions. When Im loading my lights into the batch preprocessing, its separating my frames into 2 groupings, Filter 1 and binning 1x1, but as far as I can tell the subs are all the exact same filter, binning, etc. The headers of all the files say the exact same but it always separates them into the 2 groups, Filter 1 and binning 1x1.
Next question is all of a sudden Im getting these vertical dark thin bands across my images. Its just happened suddenly and I can't figure out why. Ive tried new bias frames and darks.
Any help is greatly appreciated!!
Carastro avatar
What stacking software are you using?
Carole
gturgeon avatar
Pixinsight
Barry Wilson avatar
Which image acquisition application are you using?
Pixinsight will be using the information in the sub-exposure FITs header which describes filter and binning.
So the quesion is what information are you using in the FITS header from the acquisition application?
When you have a sub open in PixInsight click File>FITS Header selecting the open window and read the information.  Compare this information for the subs in "Filter 1" and "binning 1".
HTH
Concise
gturgeon avatar
Good info! I checked the FITSHeader. Under “Filter” the first subs have “filter #1” in the value box. The other group have “=“ in the value box and then “filter #1” in the comment box. Very strange. Everything else including gain, offset, exposure time, temp, etc was the same. Maybe I could change that in the FITSHeader and they can group back together. Thanks for the info!
gturgeon avatar
Just to update, I changed the value to filter #1 and saved the file and then it properly grouped the images. Thanks! smile
Patrick Stevenson avatar
I'm not familiar with your software since I use Nebulosity, but I know that you can use a demo version of Nebulosity that does everything except the final image will have dark diagonal lines across it.  You might check to be sure that your software you are using is your licensed version and not a demo.  I could be totally wrong but it's a thought.
Supportive
