Asi 183 mm pro and amp glow.
18 replies411 views
MaroOgaro avatar
Hello .
I'm looking for new camera only for NB imaging.  I have got asi 1600 mcc  for rgb , 1600 mmc is  too expensive for me . I have an idea to conect new camera with samyang 135 f2 .  I'm afraid of amp glow ( I had asi178mmc) . Is it a problem of asi 183 mmpro?
HR_Maurer avatar
Hi, i dont know the ASI183, but i got the QHY183. There is Amp Glow. It can be removed if calibrated properly (use darks of identical exposure, dont scale them), however some extra noise will remain.
Concise
Maicon Germiniani avatar
I have an ZWO ASI 183. I do Darks, Bias and Flats. I STACK with APP and this software works fine, but PI and DSS not.
Chris Sullivan avatar
I've got the QHY 183. There's amp glow, and it's wicked, but as long as you take your darks at the same temperature as your lights, it will calibrate out completely. I use DSS and have never had a problem… except that time I didn't set my temperature for the lights correctly. Make sure that 'dark optimization' is unchecked. In my experience, it seems to work better with dark flats than bias. The uncooled version of this camera is worthless for DSO imaging in my opinion, because you won't be able to calibrate out the amp glow perfectly.
Helpful Respectful Concise Engaging
Michael Feigenbaum avatar
I have the 183c. Amp glow is very prevalent. I learned that unchecking dark optimization AND not using bias frames gives me excellent results using DSS.
Concise
Rob Farmiloe avatar
I had an Altair 183C, it wasn't bad for lunar but i really did not like it otherwise.
In tests done with some friends with both colour and mono versions  we concluded a DSLR was a better widefield camera.
For mono i would look at other options including used cameras.
I have also have a 178MC.   I think the amp glow on the 183 was more of an issue given its possible uses.
MaroOgaro avatar
Thank you for your attentive words.
Mitch Arsenault avatar
i have the Altair Astro 183 C/M  IMX chip ( same as ZWO/QHY) and the amp glow  is minimal, what people are referring to here is the electroluminescence starburst on the right inherent in all the Sony BSI chips.  propper darks removes all of it in PI or APP , but not as much in  DSS sometimes.
HR_Maurer avatar
Mitch Arsenault:
Hi Mitch,
how do you conclude it's electroluminescence? Wouldnt the starburst depend on the pixel charge, if it was?
This starburst seems not to build up linearly with time, otherwise dark frames could be scaled after bias correction. Moreovet, the calibration result shouldnt depend on the software. If you get different results using DSS than using PI, you do not perform identical operations. Thats an issue i do not understand. Sure there wasnt some sort of optimization option enabled?
CS Hoschie
The Algorithms for dark calibrations  in PI vs Astro pixel processor and DSS are completely different according to the owners ( APP, Mabula H) for instance.
As to  the electro,,,,, i got this from the technicians from the UK of Altair Astro designers of the AA183C based on the Sony chip.
the Amp glow is at the top and bottom only … not on the right hand side like the ASI1600MM .
To me this is not a problem… others hate this camera because of the electrolum….
Rob Farmiloe avatar
Amp glow, star burst. There is a lot of it either way.  Removing that much asks the question what signal is not being captured or retained.
This aside I just did not find the images produced on DSO to be worth the cost.
My advice would be to look at all of the Widefield images from the 135mm F2 and say the Nikon 180mm F2.8 etc and see which cameras are giving results you like.
Rob
Rob Farmiloe avatar
Mitch Arsenault:
As to  the electro,,,,, i got this from the technicians from the UK of Altair Astro designers of the AA183C based on the Sony chip.the Amp glow is at the top and bottom only … not on the right hand side like the ASI1600MM
They are built and purchased from the far east, not designed in the UK.  Check the SDK file and you will see a familiar name.
Rob Farmiloe avatar
Marek,
I now use an Atik CCD with built in filter wheel.  Appreciate these are over your budget although you may pick up something similar used.
This link (QHY) i feel gives a reasonable appraisal of camera sensors and uses.
https://www.qhyccd.com/index.php?m=content&c=index&a=lists&catid=102
MaroOgaro avatar
Thank all of you for reply. I have decided to buy used atik 320 e mono. (only 400e). I would like to conect tha atik to samyang 135 f2.
Rob Farmiloe avatar
I use my Atik one 6.0 with a camera lens attached.
Both on my pier and on an Astrotrac while away.
That does give an advantage in that an arca plate or dovetail can screw to the camera housing.
I just use a Nikon F mount  to M42 adapter plus an M42 spacer for the correct sensor to lens spacing.
For longer or heavier lens i Use a carriage made up from arca parts.
You will need to check your spacing to see what filter wheels may fit. Or use one of the ready made units sold that include a filter draw. You can buy these in canon or nikon fit.   Not the geoptik version.
Rob Farmiloe avatar
A simple form for checking the FOV will be what you want.
Dont worry about hitting a sampling rate of 2.  It wont happen on widefield images
https://www.bintel.com.au/tools/astronomy-calculator/
Rob Farmiloe avatar
Rob Farmiloe avatar
For supporting a heavier lens i use one of these.  Camera to m42 - lens mount adapter.  Then fitted to this.
The lens support part can be spun around to change the amount of clearance depending on how high the lens sits.
This then fit direct to the Arca head on the Astrotrac and enables balancing.
For my main mount I  have a solid dovetail. On one end a heavy duty arca plate. The other a mount for my guidescope.
Andoer L200 Telephoto Lens Support Long Lens Holder Bracket Height Adjustable Compatible for Arca-Swiss Sunwayfoto RRS Benro Kirk Markins Mount https://www.amazon.co.uk/dp/B074PQFDS5/ref=cm_sw_r_cp_apa_i_ba6GCbF40J9RG
Recommendation for a remote scope
Hello, fellow Astrobin users! I am thinking of sending a scope to a remote location in Spain. I really grew tired of the constant bad weather. Last winter in Western France, we had as much rain as the last 2 winters combined! The 2 main questions I s...
Sep 27, 2024
Both posts discuss choosing between monochrome and color camera sensors for astrophotography equipment.
New to using a Full Frame Sensor / 50mm round filters. What kind of vignetting should I expect with an f/5 system?
Hello everyone, Now that I have the AG Optical FA12 (12.5", f/5, fl 1570mm), with a stated corrected field of 50mm, I am trying to make sure I am utilizing as much of that cone of light as possible. My imaging train currently is a little bit wei...
Jan 1, 2024
Both posts discuss optimizing camera and optical equipment setups for astrophotography imaging.
