Ritchey Chretien mirror spacing adjustment
3 replies392 views
Markus Gorski avatar
Hello everyone,
I've lost the optimal mirror distance of my TS RC 6" through a lot of adjusting.
I tried to find a solution on the Internet so that I could get it under control again.
With a Ronchi eyepiece and by calculating the focal length using Platesolving I tried it, but it was all too complicated and cumbersome for me…
Finally, I got the tip from Teleskop Express to focus the telescope with the original OAZ without extensions, taking into account the optimal back focus with the adjustment screws of the main mirror.
For the 6" I did it like this:
Telescope - OAZ - back focus from 159 mm to the camera sensor - adjust with a Chesire - Then focus with the adjusting screws of the primary mirror by turning all screws as evenly as possible.
First I did a rough adjustment during the day with an object at a great distance, then at night with a star and a Bahtinov mask. It's not quite perfect, but I was quite happy with the result (https://www.astrobin.com/full/cco1lx/C/).
Maybe this will help someone here… Best regards
cdavmd avatar
Hi,  I want to try this method but I’m confused as to what “OAZ” means?
thanks
thanks
oh, sorry, that's „Okularauszug“ in German and is called „focuser“ in English. Good luck!
cdavmd avatar
Ah lol. Thanks!
TS-Optics RC8 - Collimation : next step ?
Hi All, I received 2 weeks ago a TS Optics 8'' Ritchey Chretien, and tried to collimate it (out of the box, the stars were just horrible…. I plan to use it first with an AstroPhysics 0,67x telecompressor (reducer) to get more light and ...
Ritchey Chretien mirror spacing adjustment procedures.
Apr 3, 2021
Backfocus C8 + Barlow : Help.
Hello everyone, i have a question about the C8 back focus. Indeed, for planetary acquisition, I use a Crayford 13cm long, a X-CELL X2 Barlow, an extension tube 50mm and my 1100D but the results are not very good, as you can see… https://www.ast...
Back focus issues directly relevant to planetary imaging setup problems.
Oct 11, 2020
GUIDE: Collimating Takahashi Epsilon 130 ED w/ OCAL
We all know the reputation these scopes have when it comes to collimation. As a former RC owner I always wondered if collimation was really that difficult on an Epsilon or if people just aren't using the correct method. I've owned an OCAL v2 ...
RC telescope collimation guide relevant to mirror distance optimization.
May 13, 2024
Skywatcher Quattro 250P astigmatism tip, maybe helpful to others?
I am posting this info because my google searches turned up very little specifically about the issue I was having with my scope and the solution. This is on my Skywatcher Quattro 250P, but certainly applies to other scopes. I was experiencing astigma...
Troubleshooting optical issues in reflector telescopes similar to author's problem.
Dec 5, 2023
