a quick question for any ZWO ASIair users out there...
3 replies228 views
Richard O avatar
I have a quick question regarding the zwo asiair. i purchased this unit for the purpose of guiding but am a little confused (beginner still), Am i correct in thinking that i only need to connect the guide camera to the mount via serial/usb connectiion directly or do i need to go through the hand controller. sorry mount is ioptron cem25p. and secondly do i need skysafari or is the program skysafari skybridge included in the package.. i have not hooked it up yet for fear of not being sure on those points at the moment. Thanks for any/all help i appreciate it.
Larry S avatar
You should be able to connect the guide camera (ZWO) to either a USB hub port on your imaging camera (such as ASI1600 has) or directly to a port on the ASIAir.  Your mount should also be connected to the ASIAir via USB (with RS232 - USB converter if needed) for guiding to function.
SkySafari program is not included, just the link (bridge) to use it. Needs to be installed on your tablet or smartphone.
Richard O avatar
thank you Lakerunr
Scott Slinde avatar
I have the usb to RS232 what part do I buy to attach the serial part to a sta4 to go to my SkyWatcher Eq6R controller
Install of ZWO ASIAIR Pro, ASI120 Mini Camera, & 30 mm Guide Scope
Greetings, I just received my ZWO guide system and am excited to put it to use, however, right off the bat, I have some questions that I'm hoping others with experience can clarify: How far into the guide scope I should set the camera?Do I need t...
ZWO ASIAIR Pro installation and setup guide directly addresses your equipment questions.
Aug 26, 2020
Safely Moving an Equatorial Mount
I recently acquired an iOptron CEM25p to go with my Takahashi FS-60CB/Q. I'm still very new to the hobby and I'm wondering if there are any special considerations when moving an equatorial mount. The instruction manual doesn't necessarily...
iOptron CEM25p mount setup advice relevant to your specific mount model.
Oct 4, 2019
Dithering & Darks
Good Day to All! I live in Providence, RI under Bortle 8 skies My Equipment: Meade Series 6000 80mm Triplet APO Sky Watcher EQ6-R Pro Canon EOS Ra ZWO 30mm f4 MiniScope - Guiding ZWO ASI224mc - Guiding Notes: I guide usingan ST-4 connection, I use PH...
Dithering setup with ZWO equipment; may clarify guiding camera connection procedures.
Jan 15, 2021
