Linwood Ferguson:
Is your rationale there that mirror movement (relative to the tube where a guide camera would be mounted) is the primary culprit?
I would have thought the longer focal length itself was a reason to use them. Otherwise wouldn't people with external focusers go back to guide scopes? But I see what seems like most still including OAG's? I ask partly because I just got an external focuser and had not considered going to a guide scope at 2800mm.
As to the OP, I wonder about focusing so heavily on tilt and not backfocus. When I looked it seemed to have a backfocus issue as well, though neither was terrible.
I'd say so. You can't guide with mirror flop/shift but you could even with 3m FL (I did) with a guide scope. You'd only need a 1/5 of the effective pixel scale on the guide scope to guide efficiently. Not saying you must do it that way, just saying you could.
It isn't backfocus distance or all the off-axis stars would show the same aberrations in proportion to the distance from the optical axis, which this one do not.
It is not difficult, but it is not trivial to get the 1/5th (which to be fair I've always heard and never tried to test). For example, I have a 2800mm SCT and a 240mm guide scope, and my guide camera pixel density is lower, so I'm well over 1/10th. I'd need a significantly longer guide scope if I tried to maintain that 1/5th image scale. Though it would solve a lot of other problems, especially as I am pretty limited in backfocus with an external focuser after the flattener.
Anyway....
To me I saw some consistency of star shapes, though I think there is also tilt. Which would you work on first?
To the OP - backfocus specs are estimates. How accurate they are, and how precise they are depend a lot on the vendor and optics quality and construction precision. That's why there is a going market for spacer kits to fine tune. For example, my SCT quotes a 146.05 back focus. I think the 146 is about right, but the 0.05 added on the end gives a misleading implication of precision. Also, manufacturers may or may not build into their "55mm" (or whatever) filter thickness allowance (1/3 the glass thickness gets added back to space you include). I certainly bow to the majority here that your problem is primarily tilt, but if you head down the backfocus adjustment rat hole, trust your images, and not (completely) the specs of the gear.
There's also combinations of gear that do not add up mechanically the same as mathematically. I have a 3mm m-m adapter from Moonlite that is 3mm connected to a Moonlite spacer, but due to thread depth is 5mm connected to a spacer kit from Blue Fireball. A caliper is handy to have around.
Simple ZWO example: Camera (ASi6200) + EFW7x2 + OAG-L = 55mm. Except, with 3mm thick filters it really is 54mm, which their "paths to 55mm" didn't include.
