I'm having trouble with using flats to get flat images with a full frame sensor and 2 inch filters. Due to the large size of the of the sensor and the size of the image circle, the corners on my shots are significantly less illuminated than the c...
Discusses flat field correction issues with corners, directly relevant to white corner problem.
Hi, I use an ASI 1600 MM cool Pro CMOS camera. On a 16-bit scale (65550 total adu output) I try to keep my Flat adu to about 1/3 of total, or about 20,00 - 24,000 adu. I understand that this will keep the flats in the linear range of the camera's...
Addresses ADU levels for flat frames with similar ZWO ASI camera, highly relevant.
Hello everyone,I have several problems to be able to make the flats frames in the HA and SII filters im my setup (canon 200mm f2.8@f2.8, asi 1600mm-pro, filters optolong). I'm trying to use all possible types of ADU, but the image only gets worse...
Troubleshooting flat frame acquisition with ASI camera model, similar equipment and problem.
Hi, Does anyone have any good tips on acquiring Darks, Flats, Bias, etc? I am very new to this all, shooting with DSLR, and would love some insight to improve my photos by using such. Thanks.
General guide on acquiring flat frames and calibration frames for astrophotography.
