Polar Align Without Polaris - Good Enough for Astrophotography?
16 replies1.2k views
Mark Germani avatar
Hi Folks:
We're looking to move sometime in the next few months, and it's extremely likely that I will have no view to the North. In one case, there is a clear path from East to West, but South and North are completely obstructed.
I'm currently using an iOptron Skyguider Pro, but hoping to upgrade to to a CEM26, HEQ5 or similar (I'm siding with the CEM26 currently). I've read that there are a few ways to polar align without Polaris, including iOptron's "Polar Iterate Align". Has anyone used this method? Are these alignment methods accurate enough for astrophotography?
Thanks in advance for anyone willing to weigh-in on this!
Mark
Mark Germani:
Hi Folks:
Mark
In general, drift methods and shift methods yield very good results when applied properly. I used to do drift-align to station my mounts permanently. Nowadays I use SharpCap polar alignment routine as I can see Polaris quite well (one of the few ups of being located up North) but NINA offer a shift-alignment procedure and PHD2 a drift-alignment method that are quite OK (if set-up correctly).
V avatar
Hello, I actively image without polaris visible, as I shoot from a closed space balcony. If you opt for it, the HEQ5 should have a Sky-Watcher version of All-Star Polar alignment built in, which is what is on my Celestron CGEM II that I use. I've found that aligning 4-10 stars with pinpoint accuracy, polar aligning, re-star align, then polar align again does it for me. PHD's PA assistant shows consistant 30" +-10" accuracy to my polar alignment, and I get zero drift. I have no idea of how the iOptron PIA system works.
(Off-topic ahead) As for which mount to get if you want some input IMO, I'd go with the HEQ5 for the time being, as the CEM26 is very new and I've had horror stories from numerous friends. For the ones that did work, the performance was pretty much the same as the HEQ5.
Ed Dixon avatar
Another option is to use an iPhone app along with a phone mount device.  You can get a pretty good polar alignment with this in the middle of the day or night.  It works indoors or outdoors.  It looks like this:
PS Align Pro is the app I use.  The phone holder is a 3D printed device that is on ThingAVerse.  I have used this with my iOptron Sky Guider Pro and my AVX mount many times.
Stjepan Prugovečki avatar
N.I.N.A PA routine does the job. It is  a simple, quick and accurate procedure.
Btw, I had HEQ5  and now I have GEM28 (I think it costs the same as CEM26).
The performance is comparable, just GEM28 is much lighter and  it is somewhat more "modern" and has more options (like iPolar, WiFi, ..) included than HEQ5
Stuart Taylor avatar
Stjepan Prugovečki:
+1 for NINA's PA routine. It doesn't need a view of Polaris and works on every scope I've ever tried it with (you just need to tell it your focal length). And given that NINA does everything else you need (such as focus, target framing, filter changing, sequencing etc) - not to mention it's free! - I'd strongly recommend it.
Well Written Helpful Concise Engaging Supportive
Jim Raskett avatar
Another +1 for N.I.N.A.'s PA routine. I do have a view of Polaris, but I have tested the routine several times in random areas of the sky with very good results.
I know that you are leaning toward the CEM26, but if you do choose the HEQ5, I strongly recommend the Rowan belt mod kit. The kit along with tweaking the worms have really improved its performance.
Good luck!
Jim
Well Written Concise Supportive
Arun H avatar
Another plug for N.I.N.A's three point PA protocol.
I previously used the Polemaster with Sharpcap, but N.I.N.A's 3pa is more accurate, probably because it uses the larger aperture of the main scope.
christianhanke avatar
Hi Mark,
I´m using a HEQ5 on the terrace without sight to Polaris. For the polar alignment I´m quite satisfied with the drift analysis in PHD. In addition I marked the correct placement  of the tripod (with fixed and unchanged legs) on the terrace. With an adapter I attached a laser pointer to the pole scope and after the correct drift alignement I marked the laser spot on the wall ("artificial pole"). With this laser procedure I can easily align the mount without using the drift alignment again.
Regards Christian
Helpful Insightful Respectful
Mark Germani avatar
Hi folks!
Thanks for all the feedback. I've heard good things about N.I.N.A. too. The only issue there is that I'm running Astroberry and connecting to it from my Mac, so it'll have to be PHD2 or whatever polar-align tool the mount has onboard. But that's useful to know if I start running things from a PC in the future.
Thanks also for your thoughts regarding CEM26/HEQ5. I'm really on-the-fence as far as the mount goes, so any and all input is appreciated!
Mark
Mark Germani avatar
Ok, another question:
Has anyone tried the built-in polar align tool in EKOS? It looks like it works when Polaris is not visible. This would be handy as it’s what I use already with Astroberry.
Miguel Morales avatar
Even though I can clearly see Polaris I do live at 18 degrees north, and as such Polaris appears to the eye to be in a place other than it's actual position due to atmospheric diffraction. Hence I use the drift method of polar alignment within PHD2 which is not as simple, straight forward or as quick as using a Polemaster (or other such device) but it work excellently once one becomes thoroughly acquainted with the procedure. The accuracy of this method is really quite good and totally acceptable for use in astrophotography.
Miguel   8-)
Bob avatar
Ed Dixon:
@Ed Dixon, This looks great. I’ve looked for it on thingiverse.com but can’t find it. Can you provide a link?
dkamen avatar
Mark Germani:
Practically the same thing as NINA.
Sigga avatar
Ed Dixon:
PS Align Pro is the app I use.  The phone holder is a 3D printed device that is on ThingAVerse.  I have used this with my iOptron Sky Guider Pro and my AVX mounPS t many times.
PS ALIGN excellent app! Used with SkyGuider!
Steve Ward avatar
My favourite drift alignment method is this ,  got my HEQ5Pro to 5 minutes unguided as a test after folks told me it couldn't be done ...
https://www.cloudynights.com/articles/cat/articles/darv-drift-alignment-by-robert-vice-r2760
Doug Summers avatar
I use the Ekos PA routine regularly; it's as others have said very similar to the NINA approach, and it produces very nice results.   No need for Polaris.   Just point to a place in the sky anywhere that you can get 2 rotations and 3 images, and tell the routine which direction you're expecting it to move.   It helps to keep moves away from a meridian flip.
So, in my case, and just for convenience (could be done other ways just as well), I move the mount to ~25 degrees altitude in the East near zero dec, tell the procedure to move west 15 degrees for each move, and then it does 3 plate solves (including 2 procedure initiated rotations).   A multicolored vector is produced that makes short work of the needed knob rotations for Az & El….   Fast & effective, with only a few arcsecs of uncertainty.
CG-4 Polar Alignment & Autoguiding Options
Hello, I am very new to the hobby and currently have a Celestron CG-4 mount. I have started to get curious about if there is any way to autoguide with this mount despite it being kinda low-end. I briefly did a little bit of googling and it seems like...
Discusses polar alignment techniques relevant to mount selection and setup.
Jan 13, 2024
Zenithstar 73 II With a SkyGuider Pro
Hi there, I'm still just getting into astrophotography using an equatorial mount and am looking into getting a solid refractor telescope to go with my SkyGuider Pro. I'm thinking about the Zenithstar 73 II but was wondering if the 430mm focal...
Discusses polar alignment without iPolar for equatorial mount astrophotography.
Dec 2, 2020
SWSAGTI Polar Alignment hacks for the unguided and beginners
I purchased a SWSAGTI a few months ago, and overall have been quite happy with the unguided results, even using my Canon 600/4 lens. But there are a few things that might make polar alignment easier and more accurate for beginners. Check the scope al...
Directly addresses polar alignment methods for mounts without northern access.
Mar 24, 2024
